Tappet Tool
I don't have one of those, but I've considered it. It seems a little pricey, for a tool I probably wouldn't use more than once a year.
You have to understand, I'm a tool geek, and I can't justify its price, when compared to a short-pattern 6-point combination wrench and a short screwdriver.
It would be different if the tool had more than one (1) purpose, if lesser tools couldn't be substituted, or if I had a physical disability.
Even that fancy-dancey tool wouldn't have helped on the last Healey I adjusted the valves on; this rocker set-screw (jam nut) was so tight, I had to resort to a breaker bar to loosen it!
Note: ALWAYS use a six-point tool (wrench, or socket, if required) to loosen/tighten the jam nuts. I've seen so many cars where they've been rounded into oblivion, by open-end or 12-point tools slipping off.
memphis
memphis
Hi Randy,
I agree, it's pricey. Watch the video of the tool on the MOSS site.
The tool really makes it look easy. They probably broke the jam nuts loose before using the tool?
Thanks,
Bob
richberman
I love how they say, "It's just that fast and easy" at the end of the video. I have not found anything on these cars fast or easy except when you have it all working and you press the gas pedal! :driving:
rich
AUSMHLY
rich
Rich, I have found some things.. "It's just that fast and easy". Those situations simply required a check book and pen to pay the guy who did it for me.
I do agree, it's a bit pricey, but for a mechanic who does this day in and day out, may be just the ticket and well worth the cost.
Randy, is that flex loom over the heater hoses?
Roger
Keoke
tahoe healey said:
Watch Ebay. I got a vintage Snap-on one for 12 bucks plus 3 for shipping. I DO like it a lot and it is all real metal.
Yep I have the snap-on tool too and it is fast and easy. Sure beats the :devilgrin: out of a spanner and a screwdriver.---Keoke :laugh:
richberman
memphis said:
Randy, can you post the Snap-on part number?
Thanks,
Bob
Is it one of these? I'm not sure if it's 12mm or10mm or neither.
rich
Tool, Metric, Valve Adjustment, for cars with 12mm jam nut valve screws
Stock #: YA8880
For all cars with 12mm jam nut valve screws.Learn More
$67.60
Add to Cart
Tool, Metric, Valve Adjustment (for cars with 10 mm jam nut valve screws)
Stock #: YA8895
For all cars with 10mm jam nut valve screws.Learn More
$67.60
Add to Cart
RF Thom
Anybody recall the P&G Tool for setting valve clearance. It had a crow foot which sat on the valve spring cap, a finger which went under the rocker arm and a dial indicator. You installed the gauge on the valve cap with finger under arm and tightened the adjusting screw to '0' clearance. Then turn dial indicator to '0'. Back off the adjusting screw to desired clearance reading the indicator and tighten lock nut. Very accurate as you can see impact on clearance when nut is tightened. I loaned mine to someone years ago and it developed legs - gone forever.
Regards, Bob
AH100M BN2 Tool kit spark plug/tappet feeler gauge Austin Healey 7
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
S TR2/3/3A tappet assembly Triumph 10
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
G Tappet Noise Austin Healey 8
M TR2/3/3A Tappet Clearance confusion Triumph 3
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
Rut Brake adjuster tappet Spridgets 18
HealeyRick Rear Brake Adjuster Tappet Needed Austin Healey 2
T SPQR Tappet adjuster, Click Adjust Austin Healey 1
E Good tappet cover Austin Healey 5
L Simple fix for leaky tappet cover Austin Healey 0
T Oil leaks under carb are - tappet inspection plate Spridgets 6
M TR2/3/3A TR3 Tappet Triumph 4
KVH Another Tappet Question Triumph 9
vping Tappet cover gaskets - Need help! MG 6
Baz Tappet Inspection MG 7
MadMarx Tappet - flat or domed? that's the question Triumph 5
L Tappet Inspection Austin Healey 8
V TR6 TR6 Flat Tappet Triumph 12
Wana Tappet clatter? Austin Healey 3
vping Tappet cover gaskets and.... MG 1
W TR5/TR250 TC2500 tappet clearances? Triumph 1
W General MG 2001 MGF 1.8 Steptronic Flywheel locking tool MG 0
K TR2/3/3A SU balance tool Triumph 13
Editor_Reid MGA Seeking Items for MGA 1600 Mark II Tool Kit MG 0
D New Tool. Restoration & Tools 3
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
charlie74 TR6 handbrake adjustment tool Restoration & Tools 0
Basil Hagerty Car Valuation Tool Other British Cars 1
JPSmit some days your best tool is a credit card Spridgets 2
D My new restoration tool Restoration & Tools 13
Basil Drill Bits (and other tool reviews) Restoration & Tools 9
TomMull Wanted Churchill Tool 20sm69 Triumph Classifieds 36
steveg At last - inexpensive double crimp tool Restoration & Tools 4
Basil Multi-Tool Scraper/ Utility knife Restoration & Tools 0
Basil Now THIS is a tool box Restoration & Tools 6
drooartz The latest tool addition to the shop Restoration & Tools 25
JPSmit Tool identification quiz Restoration & Tools 16
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
JPSmit what's this tool? Restoration & Tools 12
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
H name and address of Jag tool seller located in Chambersburg pa Jaguar 3
I TR6 Chrome bezel removal tool? Knob removal? Triumph 6
N Tool Rolls and Pouches Austin Healey 14
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
TomMull Knock Off Tool Restoration & Tools 6
K BMC Supplemental Tool Kit Bags Austin Healey 14
