Sway bar interference
jcsb
Installed a 7/8" sway bar that I bought from Victoria British and while I had the shock valving out I moved the suspension up and noticed the sway bar was hitting the front bumper mount when pushed up past level. Yes the bar is centralized and it appears the former owner had installed a new bumper and mounts. Anyone else run into a similar problem? Photo shown is when the suspension is fully extended down.
John
Are you using the stock links (between the A-arm and swaybar)? Because in the picture, the end isn't shown, and looks to be pretty close to the A-arm...
Longer/adjustable links could be substituted, and I recommend urethane bushes, as the (lousy) reproduction rubber bushes will have a very short life
Yeah, those are too short! If your originals are stll usable, put the new bushes/washers on them and see how that fits. If the fit is good, replace them if necessary, and you're set.
I'd let VB know about the wrong parts being supplied.
John Turney
The arms of the sway bar should be parallel to the ground when the front suspension is at rest with the tires on the ground. I used 5 1/2" bolts and 1/8" galvanized pipe for the tube. 2" for the tube sounds about right.
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
B TR6 Sway bar Triumph 3
Hamish Racing TR2/3/3A Sway bar rose joints and diy brackets Triumph 4
S Sway Bar End Links Austin Healey 15
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
tahoe healey Sway Bar Bushings Austin Healey 3
C Front sway bar mounting? Austin Healey 10
R TR2/3/3A Front sway bar Triumph 12
Jim_Stevens TR2/3/3A Sway bar attachment points Triumph 3
H broken sway bar link - again Austin Healey 8
jfarris TR2/3/3A Front Sway Bar on a 56 TR3 Triumph 13
M TR4/4A Front sway bar measurements required. Triumph 0
PatGalvin TR2/3/3A Rear Sway Bar experience Triumph 5
H TR2/3/3A Sway bar fitting Triumph 7
davidb front sway bar BT7 Austin Healey 4
L Sway Bar / Anti Roll bar bush replacement 100/6 Austin Healey 7
B Anti-sway bar for a earlier BJ7 Austin Healey 3
A TR5/TR250 Front Sway Bar Installation Problem Triumph 3
T TR5/TR250 250 Sway Bar Link Triumph 0
1 Sway bar installation Spridgets 9
M XK140 Sway Bar Bushings Slipping out of Brackets Jaguar 1
G TR2/3/3A Front Sway Bar Installation on Wide Mouth 61 TR3 Installation Problem? Triumph 9
sim sway bar for a 58 Spridgets 3
S MGB Rear Sway Bar MG 2
doughairfield TR4/4A TR4 Front sway bar install question Triumph 9
Boggsy64 MGB Need help sway bar end bushings MG 12
C Sway bar upper installation help please Austin Healey 3
blueosprey90 MGA An Alternate Sway Bar Link for the MGA with MGB Sway Bar [ a repost] MG 1
H broken sway bar link Austin Healey 13
H WTB urethane sway bar centre bushing Austin Healey 5
T BN1 Front Sway Bar Austin Healey 0
T TR2/3/3A TR2 Sway bar questions/info request Triumph 5
O BT7 sway bar advice Austin Healey 3
T 100 4 Front Sway Bar Austin Healey 12
pkmh Sheared Bolt - Sway Bar Bush Strap to Chassis Austin Healey 29
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
R TR4/4A Tr4a, any tips about this sway bar Triumph 2
Jim_Gruber Rear Sway Bar - Needed? Spridgets 10
R TR4/4A TR4A sway bar , any vendor differences Triumph 11
G Sway bar mounting area trouble? Spridgets 14
W sway bar link bushings fit problem Austin Healey 3
Willie_P TR2/3/3A TR3/4: sway bar options [GM, Ford, Chrysler, etc] Triumph 3
Geo Hahn TR6 TR6 Sway Bar Bushings Triumph 1
G Spring, suspension and sway bar options Spridgets 15
D sway bar bushings Austin Healey 3
M TR4/4A TR4 rear sway bar installation Triumph 15
W Spitfire Rear Suspension Sway Bar?? on 1980 Spitfire Triumph 5
T TR4/4A Just finished retrofitting the TR4a w/sway bar Triumph 4
T TR4/4A Correct front radiator tray for TR4a sway bar? Triumph 6
