XK140 Sway Bar Bushings Slipping out of Brackets
mwagon
The Sway Bar to frame mount bushings that I have don't have a shoulder on either end, so slowing work their way out from under the Clamps. Their the correct size for the 5/8" dia. swaybar, as purchased from XK Unlimited. Is this a typical problem? The only solution I see is after market bushings, that have a typical shoulder, to stop their lateral movement
LarryK
Get the shouldered bushings. The ones you have may be for a later model with capped clamps.
M Wanted Jaguar XK140 OTS Battery Door Jaguar Classifieds 0
R Jaguar XK140 mystery part Jaguar 0
Marvin Gruber XK140 OTS - Pulled the trigger Jaguar 29
M XK140 Roadster Body supporting methods during Removal Process Jaguar 1
L 1955 XK140 auto choke "otter" switch Jaguar 1
Jim_Newman xk140 Jaguar 2
M Jaguar XK140 8 Blade Water Pump Upgrade Jaguar 1
Schroeders Anyone have a center top latch for an XK140 OTS?? Jaguar 3
Bayless Need XK140 thermostat Jaguar 5
G Brake fluid recomendations - 1950's JAG XK140 Jaguar 19
G 1957 XK140 - fuel gauge inop questions Jaguar 8
M XK140 tool color Jaguar 1
M XK140 oil canister color Jaguar 2
M XK140 firing order Jaguar 7
M For Sale 1957 XK140 Jaguar 2
T xk140 disc brake conversion Jaguar 0
M 1957 XK140 Jaguar 16
78Z 1957 Jaguar XK140 Zagato Coupe Jaguar 10
J Smokin', Spittin' XK140 Jaguar 6
J XK140 FHC trunk/boot Jaguar 1
J xk140 Jaguar 4
B TR6 Sway bar Triumph 3
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
LAW75 Bonnet Excessive Sway Austin Healey 6
Hamish Racing TR2/3/3A Sway bar rose joints and diy brackets Triumph 4
S Sway Bar End Links Austin Healey 15
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
tahoe healey Sway Bar Bushings Austin Healey 3
C Front sway bar mounting? Austin Healey 10
R TR2/3/3A Front sway bar Triumph 12
Jim_Stevens TR2/3/3A Sway bar attachment points Triumph 3
H broken sway bar link - again Austin Healey 8
jfarris TR2/3/3A Front Sway Bar on a 56 TR3 Triumph 13
M TR4/4A Front sway bar measurements required. Triumph 0
PatGalvin TR2/3/3A Rear Sway Bar experience Triumph 5
H TR2/3/3A Sway bar fitting Triumph 7
davidb front sway bar BT7 Austin Healey 4
L Sway Bar / Anti Roll bar bush replacement 100/6 Austin Healey 7
B Anti-sway bar for a earlier BJ7 Austin Healey 3
A TR5/TR250 Front Sway Bar Installation Problem Triumph 3
T TR5/TR250 250 Sway Bar Link Triumph 0
1 Sway bar installation Spridgets 9
G TR2/3/3A Front Sway Bar Installation on Wide Mouth 61 TR3 Installation Problem? Triumph 9
sim sway bar for a 58 Spridgets 3
S MGB Rear Sway Bar MG 2
J Sway bar interference Austin Healey 10
doughairfield TR4/4A TR4 Front sway bar install question Triumph 9
Boggsy64 MGB Need help sway bar end bushings MG 12
