My XK's previous owner installed an auxiliary switch to manually control the auto choke that is mounted on the intake manifold and I am considering going back original by removing the manual switch. I found a NOS auto choke unit thinking the original unit was defective(hence the reason for the manual switch) and was looking for advice on the subject......any thoughts??
Also, there is an adjustment screw at the bottom of the NOS "otter" switch solenoid. The screw is mounted in what looks like a strap that runs below the solenoid....and I assume that adjusts when the unit shuts off....again...looking for advice on this as well.....
thanks!!
thanks!!
