Brake fluid recomendations - 1950's JAG XK140
gtx6970
System is all new from master cylinder, All hard lines were removed and flushed with de-natured alcohol. All flex hoses are new. Wheel cylinders are rebuilt with all new seals.
Customer wants DOT5 silicone fluid installed.
Is this a good idea ?
Local tech familar with early Jag's suggested Castrol GT LMA Brake Fluid as a good alternative for a vehicle rarely driven
Thanks in advance for the assistance
LarryK
DOT 5 silicone is only good for a show car. If this person wants to drive aggressively it will not do the job, unless you buy the Racing Silicone fluids, very costly. All old Jags past and present should have Castrol DOT 4. Dot 3 will deteriorate the rubber seals over time. DOT 4 Castrol is good to both rubber and synthetic seals. The older Jags kits were Dunlop or Girling and these were rubber which need DOT 4. The DOT 5 for show cars only saves the paint if it leaks. You have to thoroghly flush all old fluid out to induce the silicone as it will not mix with other fluids. Acts like water in line. Exotexs LMA is DOT 4.
Platinum
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif
Castrol LMA.
LarryK
Don't ever spray a silicone can in the garage before painting really screws everything up. Get silicone on paint helps protect a paint job, but try to get it off to touch-up or spray. Yep, silicone is good for screwing things up eventually. Needs to be banned, but it's probably from the other side.
piman
Hello all,
I have to totally disagree with all that has been expressed.
The point made was:-
"Local tech familar with early Jag's suggested Castrol GT LMA Brake Fluid as a good alternative for a vehicle rarely driven"
Vehicles that are not driven often most benefit from Silicone brake fluid.
I will use no other brake fluid on a road car, and this is with two decades of use. I don't know what experiences you have had but the U.K supplied (U.S. manufactured) has done all it is advertised to do. It is compatible with glycol fluids but the benefits are lost if it is mixed. The ideal is to introduce it once the brake system has been overhauled.
Alec
G
gtx6970
As it sits the vehicle will get driven approx 1000, to maybe 2000 miles a year at most. Customer wants to drive it and not have to worry about failure from either the wrong fluid or miixing of 2 fluids causing the rubber components to swell or something of this nature.I am in process of a complete brake system overhaul - with a new master cylinder, all new brake flex hoses , rebuilding all the wheel cylinders with new rubber cups. All the metal lines have been cleaned and flushed . The local tech mentioned is much more familar with these early Jags than I am and he said to use either the OE recomended fluid, or preferably convert it to LMA flud at this time would be best.
R
RonMacPherson
Gee Larry,
don't tell that to my TR6, or my Yamaha FJ1200. I first installed silicone in my 6 back in 87 or so. I lived in Rancho Santa Margarita, California. Worked in Tustin and loved driving over the hills into Hemet, Perris, up in the hills above San Bernardino. Now I didn't use it for competition, but with modified suspension, headers and three Sk carbs it wasn't exactly slow. I NEVER had a problem with the silicon.
I recommend it for the requested application; Especially as it is going into a completely dry system.
jessebogan
Use LMA .It was made for the car.It is compatible with the rubber seals, and if you flush the fluid every year or two (Like you are SUPPOSED TO) you will never have a problem. This is based on 30 years of fixing british cars.
toysrrus
Hi There Folks;
I`ve owned several Jags (4 E-Types & One `57 XK140 Rdstr): In all of the above + all the other LBCs I have had; I always used "DOT 4" in all the cars and never had a problem with fading etc etc etc:
My Brit Mech Guru always suggests DOT 5 but only if the entire system has flushed out & or New:
SUMMARY: "You can`t go wrong with DOT 4":
Regards, Russ
Platinum
Umm... 'cause it WORKS? /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
As Jesse said: 30 years of fixin' British cars.
I've a few years on 'im, but am firmly in the same camp. /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
piman
Hello all,
most people, but not all, are aware of the need to renew glycol brake fluid regularly, but in reality, how many do?
Incidentally, water will Work. (But not for long) :smile:
Alec
LarryK
I bleed and renew my brake fluid every 2 years, unless I have something sitting too long, then yearly. My competition car's brake fluid is renewed before any track event.
G
gtx6970
Talked to the owner today and we are planning to use Castrol LMA , (his preference )
We work on the car on a regular basis and flushing the system semi annually is not a problem
Thanks to all btw
Platinum
6 Brake Fluid Spridgets 4
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
B General MG Brake fluid MG 7
R TR2/3/3A Brake Fluid Triumph 6
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
G Brake fluid missing Austin Healey 6
Joe Schlosser Brake Fluid Spridgets 5
steveg Silicone brake fluid conversion - existing system Austin Healey 41
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
Rut Brake fluid Spridgets 11
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
L 100/6 BN4 Brake fluid Austin Healey 17
M Losing Brake Fluid Austin Healey 8
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
petnatcar BRAKE FLUID CONTAINER for BT7 Austin Healey 0
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
tomshobby brake fluid leak? Spridgets 1
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
C Brake fluid? Austin Healey 10
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
DNK Copper in Brake Fluid Other Cars 2
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
