Oh well just chiming in...
So in this conversation is there any chance of converting terms over to "manifold pressure" (lack/excess there of)? It makes it easier to compare opinions without double negatives. I mean in the descriptions/advice of diagnostic results/expectations. :wink:
The thought about the distributor line is a good one. Made me think about the piston lift pin possibly missing and the fast idle cam screw (I think that's what it is, I have at least one that is drilled through into the throat.) If the carb bodies are reversed there may be a hole in the back of the aft unit. ( I think)
As far as test tools, there are sonic probes that locate leaks based on the air sound. They can even "see" a leak on the underside of a manifold runner on a 'V' engine. I also remember seeing an unlit propane torch with aquarium tube used to induce an RPM jump. Agree though, WD40 and carb spray are most common.
Smart money is still on a manifold gasket leak. There aren't very many holes in these SU things, and they're small...Good thing there's no homemade PCV here or this would be really complicated
