Hi,
It really does make some difference which car the rack is out of.
I'll refer to
Moss' online illustration for TR4/4A for item numbers, but you might need to look for different parts for your particular car.
Rebuilding my TR4's R&P about five years ago, I had trouble locating some parts. Other than that, the job wasn't difficult, but took some time and needs to be done right since it's an important safety issue.
At that time, I was able to get a new rack (#60), but not a new pinion (#43). One of the pinion bushings was NLA, too (#45 or 41).
The new ball joint sockets (#69) I bought were made of white nylon, rather than metal like the originals. I ended up re-using the originals, since they were in good shape.
TR4 through TR6 (I'm pretty sure), maybe others, have a bushing in the RH side of the rack tube (#58, LH steering/US spec car) that usually wears badly and nearly always needs to be pressed out and replaced. If worn, this is a major source of sloppy steering. I had no trouble replacing it myself.
There are some tab washers (#66) that lock the ball joint caps in place. I suggest always replacing these. Probably also a good idea to replace any and all springs (#54) that might have softened over the years, along with the plunger (#55)that rides on the rack, as a matter of course.
There is some adjustment, outlined in the factory manual, using shims (#52) under the top cap of the steering box.
While the rack is out is a good time to replace rack mounts, too, if needed. Depends on which car, but TR4A and later have rubber mounts (#98) that some prefer to replace with aluminum or urethane. My car has solid mounts, so no replacement was needed. If using the original rubber type, they need to be pre-loaded when the rack is reinstalled, refer to the manual.
It was a good learning experience. But honestly, considering time and parts I'd be tempted to just buy an already re-built rack assembly, if at all possible. (I couldn't find one for my TR4 at the time. I think TRF has them now.)
