T-Series Where to find strip for MG TF sidecurtain?
TR3TomG
Can anyone suggest a place to find just one strip that I need for the rear window of my MG TF? There are 4 that surround the rear window, and I just need the top one. Ive looked on the vendor sites, but cant find just the one.
Many thanks!
MikeP
Unless you happen to stumble across an ad selling it, from a private vendor and probably used, you most likely won't. Now that being said there's nothing wrong with contacting vendors and seeing if they might have a damaged set with the piece you need they would be willing to make a deal on. Or one of the ones that also has used bits, they might have one lying around.
Kelvin
I'll check around at Moss, but the strips are now being sourced as sets. The labor cost to crimp and grind the ends was too high in sunny southern California.
If I can find a broken set, I'll let you know.
Kelvin.
trrdster2000 GT6 Where to find the right tire? Triumph 8
zedvictor1 Where can I find the supporting vendors? FORUM Navigation Questions 1
R TR4/4A Where to find the chrome switch bezels? Triumph 6
HealeyDave Instrument gauge numbers by year - where to find Austin Healey 2
R Where to find a 55 100-4 Austin Healey 2
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
D TR2/3/3A Where can I find steering box bearings? Triumph 2
I How do I find where battery is being drained from? Spridgets 17
R Carb help, where to find it? Spridgets 4
S Need to know where to find info MG 1
D Where to find springs MG 8
G Where can I find the chrome "MG" air filters? Spridgets 4
sparkydave Where to find an inexpensive dial gauge Restoration & Tools 20
ekamm Where can I find #4 cup washer ? Triumph 6
R Where To Find Used Parts Triumph 17
C Where to find frames? Triumph 7
N Where can I find info on MG Midget engine numbers MG 0
N Where can I find info on MG Midget engine numbers Spridgets 6
germanmichel Where I can find a detailed frame Drawing ? Austin Healey 5
eejay56 Spitfire Where can I find a Spitfire 1500 shift handle Triumph 3
PATR8 Wedge Where does one find a Rimmer Aley Bar for TR8 Triumph 13
L Where to find BJ8 Cam Spec's? Austin Healey 3
PAUL161 Where to find, Concourse / Point car spec. sheets? MG 2
G TR2/3/3A Where can I find a complete TR3 engine parts book? Triumph 3
t8nwa where do i find a '80 softtop frame? Triumph 3
miranda Where to find the car number on a 100-6? Austin Healey 14
M Where to find "amber" fog lights? MG 2
AUSMHLY Where do I find the numbers on my car? Austin Healey 1
V Where to find an OEM hardtop? Triumph 2
L Where do you find "The Good Parts"? Austin Healey 12
svtmikey GT6 GT6 Paint - CODE 34....where can I find it? Triumph 15
R Where do I find? Spridgets 11
H Where can i find it? Triumph 3
S Where to find speaker grilles? Triumph 5
C where to find E type race cars ? Jaguar 5
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
