Where I can find a detailed frame Drawing ?
germanmichel
Hello,
I´m brandnew here, see my introduce post. I´m from germany, please excuse my bad english . At my BT7 MKI I a have to fix a accident challenge.. In result of the hit, are the front ends of the frame you say chassis? are turned in his length axis. So I have to measure the frame dimensions. In my manual I found a sketch with the main dimensions, but the drawing is very small and in bad quality. Also the positions of the wishbone supports are not dimensioned.
Is here someone who know, where I can find a detailed dimensioned drawing ?
Thank you in advance.
Bye Michel- who enjoy the next no working days :yesnod: (1th May)
Someone who find a mistake, can have it for his one.. :yesnod:
Dave Russell
Yoda - R.I.P
See if you can find something here:
https://www.acmefluid.com.au/larry/healeydraw.html
The chassis drawing can be "zoomed" to large size to read the details. "chassis.tiff.jfx"
I saved it to disk, opened it, & viewed it in "Preview" program on a MAC.
jstmorris
Hello;
A detailed frame drawing for the 100-6 to 3000 BJ7 can be found at: https://www.ahcso.com/TechTalk/TechTalk.htm
The source is DHM Co. 11B5529 - per Larry Varley’s website at https://www.acmefluid.com.au/larry/healeydraw.html I tidied & enhanced the drawing found at that web site back in 2001 for my own purposes.
I do have it in a large jpg file [2.4 Megs]. If you would like a copy, email me at jstmorris@yahoo.com and I will send it. I also have the relevant workshop manual pages in pdf format.
--Scott
germanmichel
germanmichel
Hello Dave and Scott,
thank you very much for the weblinks. This was an "overnight support" . The drawings are really in high quality. :thankyousign:
"Larry" is for me the real healey-hero ( beginning with a rusty wrack). I know this side but I did not found the drawings before.
But the positions of the wisbone mountingsupports (the angle to main chassis rail)are not defined.
What are the usal way to check/fix the position ?
Do it on the old british way....measure over the thumb and fix it ? :thumbsup:
I heard from a body shop that the normal way is to weld a new wisbone mountingsupport on the old weldseam position with a paralell adjustment to the main chassis rail.
Do you think it is good way ?
Thank you and have a nice public holiday
Michel- who spend the public holiday (also fatherday in germany) with his kids on a children celebration...
Cutlass
I had to replace one lower wishbone mount on my BJ8. To do so, I assembled the entire front suspension, including the shock, lower control arms, spring pan, spindle and trunions, but left the spring out. Then I mounted the new lower control arm mounting bracket to the control arm, and there was very little choice about where it went. After tack welding, I checked for full up and down, unbinding travel. Being assured that all seemed to work, I then finished the welding. This won't work quite as easily if you have to replace both mounts at one time, but you might take careful measurements from the other side, tack weld one mount at at time, and check for unimpeded travel, then finish the welding. Worked for me, but others may have better methods.
trrdster2000 GT6 Where to find the right tire? Triumph 8
zedvictor1 Where can I find the supporting vendors? FORUM Navigation Questions 1
R TR4/4A Where to find the chrome switch bezels? Triumph 6
HealeyDave Instrument gauge numbers by year - where to find Austin Healey 2
R Where to find a 55 100-4 Austin Healey 2
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
D TR2/3/3A Where can I find steering box bearings? Triumph 2
I How do I find where battery is being drained from? Spridgets 17
T T-Series Where to find strip for MG TF sidecurtain? MG 4
R Carb help, where to find it? Spridgets 4
S Need to know where to find info MG 1
D Where to find springs MG 8
G Where can I find the chrome "MG" air filters? Spridgets 4
sparkydave Where to find an inexpensive dial gauge Restoration & Tools 20
ekamm Where can I find #4 cup washer ? Triumph 6
R Where To Find Used Parts Triumph 17
C Where to find frames? Triumph 7
N Where can I find info on MG Midget engine numbers MG 0
N Where can I find info on MG Midget engine numbers Spridgets 6
eejay56 Spitfire Where can I find a Spitfire 1500 shift handle Triumph 3
PATR8 Wedge Where does one find a Rimmer Aley Bar for TR8 Triumph 13
L Where to find BJ8 Cam Spec's? Austin Healey 3
PAUL161 Where to find, Concourse / Point car spec. sheets? MG 2
G TR2/3/3A Where can I find a complete TR3 engine parts book? Triumph 3
t8nwa where do i find a '80 softtop frame? Triumph 3
miranda Where to find the car number on a 100-6? Austin Healey 14
M Where to find "amber" fog lights? MG 2
AUSMHLY Where do I find the numbers on my car? Austin Healey 1
V Where to find an OEM hardtop? Triumph 2
L Where do you find "The Good Parts"? Austin Healey 12
svtmikey GT6 GT6 Paint - CODE 34....where can I find it? Triumph 15
R Where do I find? Spridgets 11
H Where can i find it? Triumph 3
S Where to find speaker grilles? Triumph 5
C where to find E type race cars ? Jaguar 5
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
