TR2/3/3A Weather strip adhesive
Redoakboo
I am trying to attach the weather stripping to the bottom of the doors on my Long Door 54 TR-2. 3M Super Weather strip Adhesive is worthless! The first time you close the door, the strip comes right off. I used a 3M spray adhesive on my carpets, works great! I wish it came in a tube. I tried to spray the gap in the wx strip and you end up wearing the stuff.
Anybody found something that works?
Dick
DavidApp
On the TR3A the weather stripping is held by spring clips that go into holes in the bottom of the door. The TR2 may be different though.
David
R
Redoakboo
The TR-2 long door has a metal strip at the bottom of the door, on the inside. It has a "V" shaped weather strip that slides onto the trim; and needs adhesive to hold it on.
Dick
charleyf
The spray contact adhesive also comes in a can, with a different brand - Weldwood. If you think that contact adhesive would work try getting a small can of it. Then you can brush it on.
sp53
I like this stuff works very well, I live in the Evergreen State.
martx-5
I've used the 3M shown above and also Permatex Black Super Weatherstrip Adehesive. Both work very well.
LarryK
Might have to go to a non-chain parts store. I get mine locally thru old family parts store. Marine dealers sell it too as it has a minimum order when purchsed business wise.
Madflyer
3 M makes stuff for ever thing and direction to follow but clean is always number one. I use 3 M emblem cement on most things comes in tube like thick super glue for painted areas. Madflyer
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
Zitch TR4/4A Door Weather Strip Channel - Was this added? Triumph 4
KVH General Tech Help With Rusted Weather Strip Channel Triumph 1
tahoe healey BJ8 wind screen top weather strip Austin Healey 19
B BJ7 Weather Strip Installation Austin Healey 2
memphis Door Window Weather Strip Austin Healey 3
tr7andtvr 280I weather strip source TVR 1
Dadandson Weather Strip Clips Spridgets 4
B BE Door Weather Strip Fit Spridgets 10
AUSMHLY Door weather strip clips Austin Healey 5
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
algot1901 Weather stripping and rubber parts Other British Cars 1
R TR2/3/3A Weather Gear Triumph 3
Rob Glasgow Hardtop Weather Austin Healey 10
R Very Difficult cold weather starting problems! Austin Healey 21
steveg Healey hot weather driving observations Austin Healey 2
NutmegCT Window weather seal repair Restoration & Tools 4
M_Pied_Lourd TR2/3/3A Storage of Weather Gear Triumph 12
NutmegCT How to remove old weather stripping Restoration & Tools 8
bugedd How is your driving weather? Spridgets 12
GTP1960 TR2/3/3A Weather seal between apron & wings? Triumph 4
Sherlock Jensen FF [in winter weather!] Spotted 5
Scotsman TR2/3/3A TR3 door weather seals Triumph 22
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
R Choke Not Working In Cool Weather Austin Healey 15
Rut Weather Spridgets 17
M TR2/3/3A Weather question Triumph 9
Trevor Jessie Confused about top down driving weather [off topic] Spridgets 43
M Weather factor Triumph 2
T Soft Top Weather proofing on100 4 Austin Healey 12
E Lovely weather in the UK today Triumph 9
F Replace 1500 Door Fuzzy Weather Seal Triumph 3
A Nice weather, no Sprite! Spridgets 3
DNK Weather Pack Restoration & Tools 0
G TR6 TR6 door rattles/weather stripping Triumph 0
tahoe healey Rendezous weather. Austin Healey 1
dougie PNW Dry Winter Weather Austin Healey 7
BugeyeNJ58 Thermostat question - is it needed in hot weather? Spridgets 5
PATR8 Well the early nice weather was great Triumph 2
nevets No weather for a drive in the Healey Austin Healey 6
angelfj1 Today's Weather - So nice that . . . . Triumph 5
theleisure Cold Weather, Oil Pressure Spridgets 10
bighealeysource Weather proofing a garage Austin Healey 3
Morris Driving weather! Spridgets 50
T Weather and Transportation - alternate thinking? Spridgets 43
S Jag barely runs in cold weather Jaguar 7
Woodie window weather strips Spridgets 3
B Nice weather - Got some stuff done Spridgets 5
mrv8q Today's weather report... Triumph 68
RickB Cold weather and oil viscosity? Spridgets 8
