Bruce_B
I'm not expert but with everything hooked up, if I push the carb piston up and push the throttle open, shouldn't there be gas spraying into the Carb..coming out of where the needle sits?
Ain't happening here. I unscrewed the bottom of the carb (after removing from car and airing it out), put an hose onto the fuel inlet and blew into it while I raised and lowered the fuel float. When I pushed the float up...no air come in from the fuel line, when I lowered the float down, air came in.
Something wrong here? I'm getting ready to swap on a set of SU's I have from my 1098 engine, but I'd really like to use this carb.
Thanks...
Thanks...
