TR6 Steering rack disassembly
Rut
I was pulling a TR6 steering rack assembly apart to: 1. See how it’s done. 2. Try my hand at refurbishing it. And 3. Discover if most of the parts will interchange lhd to rhd. Everything went well and I found that everything but the pinion and housing/tube interchange. When I say well, I should add that I watched a couple of utube videos and read an article on disassembly and found that you do not drive out the pinion or the pinion bushing from the bottom as this will distort the bushing, contrary to what was posted. The good part of the story is that the bushing can be repaired/replaced without too much effort. The rack has been reassembled and works beautifully!
Rut
LarryK
Feels good to figure it out and get it done and works fine. Good job.
glemon
Love the forum for this stuff, have torn most everything apart on my LBCs, but never a steering rack good information ( as an aside, never figured out why old cars have the worm gear type steering boxes, if I were designing a car from scratch it seems like it would be a lot more obvious and straightforward to design and manufacture an R & P setup.)
M TR6 TR6 steering rack disassembly Triumph 5
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
PAUL161 T-Series TF Steering Rack MG 0
E TR6 Strange Steering Rack Cap Triumph 3
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
Simmo TR2/3/3A Steering with Escort rack Triumph 5
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
M TR5/TR250 Steering Rack Fitment/Geometry Theory Assistance Required. Triumph 1
M TR6 Power Steering Rack & Pinion. Triumph 3
C Steering Rack Spridgets 17
M TR6 Replacement Steering Rack ? Triumph 7
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
B TR4/4A Steering rack clearance Triumph 21
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
W Advice please on 1930's? steering wheel and rack Other British Cars 3
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
T Steering Rack Lubrication Spridgets 3
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
B Now a steering rack question Spridgets 4
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
matmire New steering rack question... Spridgets 3
Feathers SP250 steering rack Other British Cars 18
BoyRacer Rack & Pinion steering for 3000 Austin Healey 12
T Lubricating the steering rack on a Bug-Eye Spridgets 12
Keith_M steering rack inner ball joint Spridgets 14
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Michael Oritt Spitfire Steering rack dimension needed Triumph 1
W What is the purpose of the brown wire on this steering rack? Spridgets 19
tinman58 TR5/TR250 RHD Steering Rack Triumph 0
doughairfield TR4/4A Steering rack placement Triumph 2
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
P TR6 Steering Rack TR6 Triumph 2
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
texbears3 TR4/4A Fan Ext rubbing Steering Rack Triumph 7
N Spitfire Question on solid steering rack mounts! Triumph 3
RickB 78 Midget steering rack lube? Spridgets 4
P Steering rack adjustment??? Spridgets 6
M Steering rack boot clamps Spridgets 14
D Steering rack shim??? Spridgets 7
Scotsman Pros and Cons to a Steering Rack Conversion Triumph 18
T TR4/4A Compressing steering rack bushes - TR4A Triumph 12
tinman58 TR5/TR250 TR 250 Steering rack ? Triumph 2
tinman58 TR 259 steering rack Triumph 1
PAUL161 Steering Rack Oil MG 6
G TR6 TR6 Steering Rack Mounts Triumph 17
P Steering rack lubrication Triumph 6
jhorton3 New Steering Rack Prices Spridgets 11
D Steering Rack Boots Triumph 3
