New Steering Rack Prices
jhorton3
I've been looking at new steering racks, and I'm seeing a wide spread on pricing from different vendors. Are these racks supplied by the same manufacturer?
Jim_Gruber
Jim, I upgraded my rack on Bugsy my '68 by replacing the pinion gear. It provided much less play in the rack. For the older racks this was a pretty inexpensive fix. For the racks post '72 when they went to the Triumph style racks not sure if this was an option.
mrsprite
I can't answer your question, but I bought a new rack from Victoria British about 4 or 5 years ago and haven't had any problems with it. I guess the only "problem" was steering was a little stiff after installing it (had to manually correct the wheel after turning), but it loosened up soon thereafter.
JOeyKnapp
I just ordered a rack from VB when I did my freight order.. I added up the pieces I needed to fix my rack and buying the new one was only a little more money. Hopefully it works out well.
jhorton3
jhorton3
VB's version is around $149 vs. Moss price of $179 as of this writing. If they're made by the same manufacturer then I know which one I'll be going with. I checked with one of the Moss discount sites and the price is close to $200. It's the same part number and description as Moss. Pays to shop around.
RickB
Did you ask Moss resellers who are members here?
jhorton3
jhorton3
Not yet, but I would like to see what their price difference is.
nomad
Can you fit that later style rack to a early car???
Kurt.
jhorton3
jhorton3
I think there's slightly different tracking and ratios between early and later racks.
Different TRE and steering arms too.
JOeyKnapp
Just opened my boxes. The rack I got from VB was made in Argentina.. I will post up a picture too...
nomad
Well, I just salvaged my last good early rack from my parts stash. Looks like I will have to try to rebuild one in the future. They're very fussy as to what will give smooth steering.
Kurt.
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
PAUL161 T-Series TF Steering Rack MG 0
E TR6 Strange Steering Rack Cap Triumph 3
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
Simmo TR2/3/3A Steering with Escort rack Triumph 5
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
M TR5/TR250 Steering Rack Fitment/Geometry Theory Assistance Required. Triumph 1
M TR6 Power Steering Rack & Pinion. Triumph 3
C Steering Rack Spridgets 17
M TR6 Replacement Steering Rack ? Triumph 7
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
B TR4/4A Steering rack clearance Triumph 21
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
W Advice please on 1930's? steering wheel and rack Other British Cars 3
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
Rut TR6 Steering rack disassembly Triumph 2
T Steering Rack Lubrication Spridgets 3
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
B Now a steering rack question Spridgets 4
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
matmire New steering rack question... Spridgets 3
Feathers SP250 steering rack Other British Cars 18
BoyRacer Rack & Pinion steering for 3000 Austin Healey 12
T Lubricating the steering rack on a Bug-Eye Spridgets 12
Keith_M steering rack inner ball joint Spridgets 14
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Michael Oritt Spitfire Steering rack dimension needed Triumph 1
W What is the purpose of the brown wire on this steering rack? Spridgets 19
tinman58 TR5/TR250 RHD Steering Rack Triumph 0
doughairfield TR4/4A Steering rack placement Triumph 2
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
P TR6 Steering Rack TR6 Triumph 2
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
texbears3 TR4/4A Fan Ext rubbing Steering Rack Triumph 7
N Spitfire Question on solid steering rack mounts! Triumph 3
RickB 78 Midget steering rack lube? Spridgets 4
P Steering rack adjustment??? Spridgets 6
M Steering rack boot clamps Spridgets 14
D Steering rack shim??? Spridgets 7
Scotsman Pros and Cons to a Steering Rack Conversion Triumph 18
T TR4/4A Compressing steering rack bushes - TR4A Triumph 12
tinman58 TR5/TR250 TR 250 Steering rack ? Triumph 2
tinman58 TR 259 steering rack Triumph 1
PAUL161 Steering Rack Oil MG 6
G TR6 TR6 Steering Rack Mounts Triumph 17
P Steering rack lubrication Triumph 6
D Steering Rack Boots Triumph 3
F steering rack dimension British Motor Corp 4
