78 Midget steering rack lube?
RickB
I pulled the plug on the rack while lubing up the front suspension.
There's something vaguely greasy on the end of the plug I wouldn't call it oil or grease though.
What is supposed to go in the rack, and how do you get it into that small hole?
I have heard some say oil, som say gear oil and some say grease.
If I could find a zerk that fits the hole would it be a problem if I pumped grease in there?
RickB
RickB
I bought an oil can with a flexible hose and conical brass end.
At first I squirted a little gear oil in and worked the rack back and forth.
Then I just held the end of the hose in the hole and pumped.
I have no idea how much should go in there but it has some now and that is better than the none it had.
Technically, the later style racks call for grease.
RickB
RickB
Then they should come with a zerk.
Being supplied from the factory with a plug cannot invite the use of grease.
RickB
RickB
Well the rack is a lot smoother now, I hadn't realized how sluggish my steering was until I added some lube!
Next time I'll have a grease fitting handy to install.
tony barnhill '63 Midget Steering Rack Spridgets 6
77_MG_Midget Rack & Pinion Steering question, 1500 midget Spridgets 2
K 1968 Midget Steering wheel Spridgets 1
M Midget steering column Spridgets 3
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
Jer 67 Midget Original Steering Wheel Rescue Spridgets 4
Gray_Cat 62 Midget w/Right Side Steering Spridgets 16
RickB Need seats & steering wheel MKII Sprite/MKI Midget Spridgets 47
H Midget steering wheel hub question Spridgets 1
H Midget steering wheel hub question Other Cars 0
tony barnhill Midget Steering Spridgets 10
R How to remove a Midget steering wheel Spridgets 8
N PLEASE HELP! - Midget steering column removal? Spridgets 7
RickB 72 steering wheel in a 78 Midget? Spridgets 6
B Will a 1978 Midget Steering Wheel fit a '79 Midget Spridgets 6
waltesefalcon Midget steering wheel MG 2
A Slanted steering wheel on 76 Midget Spridgets 9
F Midget with heavy steering and no recoil. MG 7
RobSelina 13" Steering Wheel for a Midget? MG 7
R Midget steering wheel play MG 1
captobvious Sprite/Midget steering wheel nut Austin Healey 2
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
