Midget with heavy steering and no recoil.
Fretslider
Hi, I have only had my Midget for 6 months but the steering is getting noticably heavier and there is no recoil.
can anybody suggest possible reasons for this?
Bugeye58
Re: Midget with heavy steering and no recoil.
Welcome to the best forum for British cars anywhere.
Probably the most common cause for this problem is lack of lubrication at the kingpins. Sometimes the grease gets hard, and the steering becomes a chore. Try forcing grease in there, and see if that helps. An extreme measure is to <u>gently</u> heat the kingpin area, after removing the zerk fittings, and try to melt the solidified grease out, then try to pump fresh in.
Another possibility is that someone has pumped grease rather than gear oil, into the steering rack, with the same result. Binding of steering components, or mis-adjusted upper trunnions may also be the cause, but I would go for the kingpins first.
I would disconnect the tie rods from the steering arms, and try to move each wheel individually to isolate the rack as being the cause.
You have come to the right place, and we should have the problem isolated and resolved shortly.
Jeff
Welcome aboard !
i guess i would check the obvious first...Tire pressure.
as far as recoil, i dont have much return to center force as well. not sure why.
mark
F
Fretslider
Am waiting to have one kingpin replaced in order to get tracking corrected. Once done I will check out the grease situation. hopefully once work done steering will be much improved.
Friend of mine who drove car recently seems to think lack of recoil is dangerous. Maybe I'm just used to it being the way it is.
Bruce74B
If you are replacing one kingpin, I would do both, unless you are just repairing accident damage...maybe even then. One quick way to see where it may be binding is to jack up the front end work the steering wheel...if it still is stiff, chances are it is in you steering rack. I am betting it is your kingpins though and would seriously consider a rebuild of both this winter.
Bruce /ubbthreads/images/graemlins/driving.gif
F
Fretslider
Thanks for the advice guys.
hoping to get some work done this weekend. I'll let you know how I get on.
Unfortunately my other 'reliable' german car has just cost me a fortune so 2nd kingpin replacement will have to wait a while. c'est la vie.
Steve aka Fretslider
F
Fretslider
The good news is that now I've replaced the kingpin, fitted two new tyres and had the tracking sorted the steering is a lot lighter and a lot more positive. Just need to do the front springs now to stop the wheel rubbing on the wheel arch.
hi Fret, do you have big tires in the front or just weak springs?.. how about the recoil? i am beginning to think they dont have much to begin with.
mark
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
G 79 Midget 1500 overheating Spridgets 2
G 79 Midget Clutch issues Spridgets 9
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
