Steering Rack
carolien
I am rebuilding the steering rack on my 1959 Bugeye. The inner balljoints do not have grease nipples. Do you have to grease them before you assemble? I don't see how the single grease nipple on the rack is
getting grease into these ball joints.
C
carolien
I've also used grease in the past. I have grease in it now but like the idea of corn head grease. is mixing the 2 a problem?
jlaird
I am not so sure that grease grease is the answer or what was used initially. Although I expect it was very heavy oil. Miss Agatha had corn head grease which seemed to work well and what I would use in the future.
Yep, corn head
Rut
Another vote for corn head grease!
Rut
Jim_Gruber
Bought a new Grease gun at HF, added corn head grease. no more leaking rack. Of course I have the tip of the grease gun permanently attached to the rack fitting. Went on once and now cannot remove it. Had other things to worry about that have taken priority. On my Roundtoit List.
jlaird
Ha, bigger hammer.
jlaird
ok, that's what it is called, wait for it..........
You can get it from any farm supply store.
Was developed to lub the corn picker heads on corn pickers. You know the big machines farmers use to pick corn.
And that's the facts folks. Tractor supply had it where I lived.
NLGI 00 spec grease ... also used in cotton picking machines and a whole bunch of other harvesting equipment.
Dscarson
He nipple on the steer rack is for oil, not grease. I believe the thought is that if you disassemble the rack this is the easiest way to fill it back up. It takes ten ounces of hypoid oil
jlaird
Its for oil. We use Corn oul from farmers supply.
Jim_Gruber
And with Hypoid Oil it leaked from the where the the Gear that connects from Steering column to the rack. My brain is forgetting the name of that gear. Pumps Corn Head grease into the rack, no more leak period.
Jim_Gruber
Thanks Rick. Yes it was there back in the recesses of my brain. I replaced that pinion gear on my '68 many years ago. Was cheap at the time like $7.95 IIRC. Really sharpened up steering feel. Not sure if that gear is even available anymore.
twas_brillig
To summarize: the original manual called for oil to be pumped into the rack - clean out your 'grease' gun, pour the oil into it, then pump it into the steering rack. Since then, a lot of folks have moved to the corn head grease, with the advantage being that it lubricates extremely well and doesn't leak out. Same deal: clean our your grease gun, add enough corn head grease, and pump it into the rack. I believe that the consensus is to fill the rack, as the stuff won't flow throughout like the oil would. Have the wheels up and spin the steering wheel back and forth in both cases.
Me, I use Royal Purple 75W-140 (and I don't remember why I made that specific choice). I removed the grease fitting, and slowly poured the stuff in (small funnel) and moved the steering wheel back and forth. I don't remember if I attempted to fill the rack or used the recommended volume or just added the recommended minimum and then more. I do remember it as being a bit of a slow process, to move the oil out of the fill area and off to the various extremities.
If I've erred here in my summary, I trust that someone will speak up. And can anyone tell me how to not have my signature stuff show up? I knew how to do it on the old system, but haven't figured it out here. And absolutely no implied criticism of all the work and effort that went into the current BCF. Later, Doug
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
PAUL161 T-Series TF Steering Rack MG 0
E TR6 Strange Steering Rack Cap Triumph 3
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
Simmo TR2/3/3A Steering with Escort rack Triumph 5
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
M TR5/TR250 Steering Rack Fitment/Geometry Theory Assistance Required. Triumph 1
M TR6 Power Steering Rack & Pinion. Triumph 3
M TR6 Replacement Steering Rack ? Triumph 7
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
B TR4/4A Steering rack clearance Triumph 21
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
W Advice please on 1930's? steering wheel and rack Other British Cars 3
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
Rut TR6 Steering rack disassembly Triumph 2
T Steering Rack Lubrication Spridgets 3
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
B Now a steering rack question Spridgets 4
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
matmire New steering rack question... Spridgets 3
Feathers SP250 steering rack Other British Cars 18
BoyRacer Rack & Pinion steering for 3000 Austin Healey 12
T Lubricating the steering rack on a Bug-Eye Spridgets 12
Keith_M steering rack inner ball joint Spridgets 14
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Michael Oritt Spitfire Steering rack dimension needed Triumph 1
W What is the purpose of the brown wire on this steering rack? Spridgets 19
tinman58 TR5/TR250 RHD Steering Rack Triumph 0
doughairfield TR4/4A Steering rack placement Triumph 2
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
P TR6 Steering Rack TR6 Triumph 2
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
texbears3 TR4/4A Fan Ext rubbing Steering Rack Triumph 7
N Spitfire Question on solid steering rack mounts! Triumph 3
RickB 78 Midget steering rack lube? Spridgets 4
P Steering rack adjustment??? Spridgets 6
M Steering rack boot clamps Spridgets 14
D Steering rack shim??? Spridgets 7
Scotsman Pros and Cons to a Steering Rack Conversion Triumph 18
T TR4/4A Compressing steering rack bushes - TR4A Triumph 12
tinman58 TR5/TR250 TR 250 Steering rack ? Triumph 2
tinman58 TR 259 steering rack Triumph 1
PAUL161 Steering Rack Oil MG 6
G TR6 TR6 Steering Rack Mounts Triumph 17
P Steering rack lubrication Triumph 6
jhorton3 New Steering Rack Prices Spridgets 11
D Steering Rack Boots Triumph 3
F steering rack dimension British Motor Corp 4
