Steering Rack Boots
DougF
The TR6 is coming up for inspection and the boots were maybe 6 years old and in need of replacing. Since both sides were either torn or blown out, it was time to replace them.
The passenger side was fairly easy, though the boots aren't really willing to give and getting past the tie rod nut is a small challenge. But then there is the driver's side.
I remember last time I swapped them out I was able to do it with the steering rack in place, though I remember it wasn't a pleasant experience. I must have said some very special prayers that day because I have no idea how it is possible to do that job with the rack in place....it's hard enough to get the boot in place let alone secure it. I ended up using safety wire but with much struggle.
This is one of those products that I would be willing to pay a high premium for a very high quality rubber, just to know I'd never have to perform that task again.
Fortunately, this is the last bigger project I need to do on the 6 and can soon start back on the TR3. I really want to have a TR3 on the road again.
SkinnedKnuckles
I too struggled with the drivers side. The combination of greasy hands and placement made slipping the boot in place as is impossible. By chance I decided to turn the end of the boot back on itself, then butted it against the bracket and flipped the "turned" part back over the bracket. I worked the first time and surprised the heck out of me.
Geo Hahn
You're done now but FWIW here is the technique I used on my TR4 and later on my VW...
Stretched the boot end over a glass bottle (filled with warm water which may also help):
After some time for it to relax I took it off the bottle and stretched it over the open end of a lid from a spray can:
I then cut the lid off leaving a ring of plastic which holds the boot open:
Once the ring & boot are over the rack (obviously the can lid must be a larger diameter than the rack) the ring can be cut and pulled away.
DougF
I don't remember how I did it last time, but the addition of oil cooler lines made access extremely limited. My steering column was looking pretty shabby which made the decision of pulling the rack a little easier.
Thanks for the ideas. I hope I never have to do it again.
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
kyreb1862 Steering Rack Boots MG 6
cdsmith Question about steering rack boots. Spridgets 13
Monark192 Steering rack boots Spridgets 5
B TR6 TR6 Steering Rack boots Triumph 6
B E-Type steering rack boots Jaguar 2
Obtong Filling Steering Rack/Boots MG 6
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
PAUL161 T-Series TF Steering Rack MG 0
E TR6 Strange Steering Rack Cap Triumph 3
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
Simmo TR2/3/3A Steering with Escort rack Triumph 5
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
M TR5/TR250 Steering Rack Fitment/Geometry Theory Assistance Required. Triumph 1
M TR6 Power Steering Rack & Pinion. Triumph 3
C Steering Rack Spridgets 17
M TR6 Replacement Steering Rack ? Triumph 7
B TR4/4A Steering rack clearance Triumph 21
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
W Advice please on 1930's? steering wheel and rack Other British Cars 3
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
Rut TR6 Steering rack disassembly Triumph 2
T Steering Rack Lubrication Spridgets 3
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
B Now a steering rack question Spridgets 4
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
matmire New steering rack question... Spridgets 3
Feathers SP250 steering rack Other British Cars 18
BoyRacer Rack & Pinion steering for 3000 Austin Healey 12
T Lubricating the steering rack on a Bug-Eye Spridgets 12
Keith_M steering rack inner ball joint Spridgets 14
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Michael Oritt Spitfire Steering rack dimension needed Triumph 1
W What is the purpose of the brown wire on this steering rack? Spridgets 19
tinman58 TR5/TR250 RHD Steering Rack Triumph 0
doughairfield TR4/4A Steering rack placement Triumph 2
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
P TR6 Steering Rack TR6 Triumph 2
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
texbears3 TR4/4A Fan Ext rubbing Steering Rack Triumph 7
N Spitfire Question on solid steering rack mounts! Triumph 3
RickB 78 Midget steering rack lube? Spridgets 4
P Steering rack adjustment??? Spridgets 6
M Steering rack boot clamps Spridgets 14
D Steering rack shim??? Spridgets 7
Scotsman Pros and Cons to a Steering Rack Conversion Triumph 18
T TR4/4A Compressing steering rack bushes - TR4A Triumph 12
tinman58 TR5/TR250 TR 250 Steering rack ? Triumph 2
