Standard 10 in S.C. on Craig's list for $300
Deleted member 8987
Is that a wide choke shotgun pattern on the driver's door?
hilsideser
hilsideser
yeah, the driver's door is shot!
kodanja
Aint choo got lernt ta spel er reed yet..............
Andrew Mace
angelfj said:
must have been using it to run squeeze!
Funny...because I just happened to catch <span style="font-style: italic">Thunder Road</span> on TV last night! Can't picture Robert Mitchum fitting into, let alone outrunning revenuers in, a Triumph 10.... :laugh:
Twosheds
TOC said:
Rednecks cain't spel.
Forum members who live in glass houses should not throw stones.
Deleted member 8987
Said the guy from Mary-land.....
Fortunately, I have ieSpell on my confuser....
gsalt57tr3
if anyone is going to buy it, ill kick in $50 for the red and black "10" bonnet badge.
Andrew Mace
Not for YOUR 10, I hope? Like the later TR3As, it would've had a blue-and-white badge. :wink:
Again, if only it were much closer to at least one of us 10 owners....
gsalt57tr3
Sorry Andy, i broke the authentic guidelines with the spitfire 1500 and weber downdraft, not to mention the monza exhaust. I just think the red and black looks better.
Andrew Mace
No problem; all is forgiven. I'll ask the judge to lift the temporary (badge) restraining order! :laugh:
In fairness, I must say that, should I ever get my Standard Pennant into running and driving condition, I might occasionally swap on the (genuine, from the Canadian models and intended also for the US market, although Pennants never did get sold in the US) Triumph Pennant bonnet badge I got years ago!
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
M TR2/3/3A Standard Engine Trust Washer Thickness Triumph 18
S General Tech Standard for the Girling Bubble Flare Triumph 15
T Wanted Workshop manual for Triumph 10 [Standard 10] Triumph Classifieds 4
Mickey Richaud General TR Standard 10 Pickup! Triumph 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
NutmegCT 1951 Standard Vanguard Other British Cars 3
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
Tim Tucker TR2/3/3A TR2-4 86mm standard rings Triumph 10
RickB standard size lug studs for 78 Midget? Spridgets 3
C Triumph Standard Flying 8 Triumph 5
M Thak you and Metric or standard.... ? Austin Healey 5
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
rlich8 Standard-Triumph Engine Package Diagram Triumph 4
K Early 50's Standard Triumph 1/2 Ton? Triumph 8
wangdango Vandervell bearings for 100M, standard, main Austin Healey 3
bighealeysource Pertronix coil verus standard Lucas coil Austin Healey 3
QuickSilver Technical: Converting From Wire Wheel To Standard MG 6
kurts100 Bugeye Lever Shocks/Standard or Heavy Duty Rebuild Spridgets 14
K TR2/3/3A Standard Continental Touring Kit for TR3 on EbayUK Triumph 0
TR4nut Standard Triumph Gray Colors for Russ.. Triumph 15
K 1950 Standard Vanguard Other British Cars 2
T Neat project - Triumph Standard 10 Triumph 11
Ohiobugeye Metric or US Standard Threads? Spridgets 26
Wirewheels Did the BJ7 come with OD standard? Austin Healey 11
germanmichel Standard clearance mainshaft of the transmission ? Austin Healey 3
W TR10 / Standard Axle for Lotus Triumph 10
pakiwi 1275 Cam Specs - Standard Spridgets 1
PeterK standard-triumph hardware catalog Triumph 7
MadRiver TR6 Standard TR6 Tires? Triumph 2
ncbugeye Tyres for standard Bugeye rims Spridgets 1
G Standard Vanguard Paint Code Other British Cars 4
Alan_Myers If I had room, time, $! FS: '47 Standard Flying 14 Triumph 2
Sherlock Standard Herald [India] Other British Cars 5
A MGB How much Torque can a standard MGB gearbox handle? MG 5
bobh A Radical Idea? Or An Old Standard? Triumph 11
gsalt57tr3 1953 Standard Vanguard Phase II Other British Cars 0
gsalt57tr3 Standard Vanguard Triumph 2
gsalt57tr3 Standard Vangard in St. Louis MO Triumph 2
Webb Sledge David Vizard: Tuning Standard Triumphs Triumph 2
Sherlock History question - Standard-Triumph of Belgium Triumph 3
R air shocks vs.standard type? Triumph 3
Webb Sledge Tuning Standard Triumphs Triumph 0
4 1947 Standard Flying 14 Info Other British Cars 5
UltimateQuestion Standard-Triumph T-10 Triumph 10
S Standard Triumph publications list source wanted Triumph 0
simon1966 Hard top for 4 seater just popped up on local Craig's List Austin Healey 2
hilsideser B parts on local Craig's List MG 0
hilsideser GT6 67 GT6 on Craig's list Triumph 0
