A Radical Idea? Or An Old Standard?
bobh
I'm opening my self up for lots of comments on this one.
The top on my '75 TR6 is the original. In general it is in excellent shape. It's shrunken a little on the sides so the velcro doesn't do it's job, the windows need to be cleaned. Neither of these are real issues. The problem was the color had become more gray than black in some areas. Plus there were dark spots in the gray.
I tried several cleaners and some "Revitalizers, Rejuvinators" but none really worked. Years ago I used something called tire black, or something similar, on my tires and top. As I recall it was an awful lot like shoe polish. Everything now days seems to be like Armorall, greasy and too shiny.
Last weekend I took the plunge and put a coat of black Kiwi Shoe Polish on my top. It looks great. In fact I followed up with another coat last night. I let it dry and buffed it with a soft cloth. Nothing has come off on my car cover, the color is uniform and black and there is not too much shine. It not as shiny as the old Amco replacement tops of yesteryear.
Has anyone else ever done this? I'll keep you posted on the long term results. For now I'm happy (maybe a happy idiot?)
Some of you may remember that I use Pledge furniture polish on my dash top and crash pads. It works great. I'm working on something to clean the reflective strip.
T
Tinster
Yo Bob!!
I have used the Kiwi line of shoe polish quite
successfully. I installed green and cream colored
marble mosaic countertops in our kitchen and needed
a decent finishing product.
After much experimentation, I tried Kiwi neutral shoe
polish. Fantastic!! 8 coats hand laid and buffed.
After 6 years and 2 per year new coats, it is still
a work of art.
d
mailbox
Ok, lets see. You could replace your top for some ungodly anount of money which, if you are like me, you don't have or buy a can of shoe polish every so often and spend a little "quality time" with the 6. Boy, that's a tough one. /ubbthreads/images/graemlins/smirk.gif
foxtrapper
Old car detailers trick from the dawning of time. Used on tires, rubber trim, etc. Works well on shoes too, or so I hear. Have my doubts about that one though. /ubbthreads/images/graemlins/wink.gif
If you ever happen to run across a product called "Black Again" I'd suggest picking it up. That's taken previously white trim and returned it to the original black. Even trim that I've bleached with halogenated solvents recovered with it.
Another old world trick, motor oil. You've already noticed how shiny faded old paint looks from your greasy hands. Take an oily rag and wipe the car down. It'll look remarkable for a week or so.
R6MGS
[ QUOTE ]
[/ QUOTE ]
I've used that one more than a few times...Great old trick...Armoral works pretty well also....Especially the new Armoral tire gel stuff.
hondo402000
NAPA sells a vinal( I know thats not how its spelled but its early, vinal dye in a spray can that actually melts into the top, you might try that
Harry_Ward
After tape-ing off the white piping on my original rear seat I sprayed out the NAPA burgendy vinyl dye and it actually came out really good. The PO put a Michelin tire on the rear seat and there it sat for ten years. No matter what I tried I could not get the Michelin lettering or black stain off the vinyl. This NAPA vinyl dye stuff covered it great. Comes in a 12 oz. spray can. Recommend light coats to build up a finish coat. Practice on a piece of cardboard to see what it takes to make it run.
Tomster
I wonder if the KIWI black will eventually soak thru the vinyl and start to appear on the inside canvas of the roof ...
bobh
bobh
" It'll look remarkable for a week or so"
I also waxed the car with Zymol last weekend. It looks better than anything I've used for quite a few years. The label says it's all natural and contains a couple of oils. I remember using carnuba paste wax on my first car, a '69 MGB. It was a faded dark blue. The oil in the wax made it look great for a couple of days. After a week the oil had evaporated and the fade was obvious. I was young and still paying for the car ($1250 in '72). I couldn't afford new paint so I waxed it every week for most of the summer. Eventually I saved enough to get a full repaint ($125).
I winder how long the Zymol shine will last.
G
[ QUOTE ]
[/ QUOTE ]
Zymol is all I ever use. Best darn wax on the market as far as I am concerned.
Bill
R6MGS
I use Zymol on my indoor cars....It will last a long while on a car that isn't exposed to the elements....But for cars that have to sit outside, or are driven daily I like Nu finish...It lasts usually about 3 months or more before it loses it's gleam.
Michael Oritt Vapor lock--a foolproof if a bit radical solution... Austin Healey 8
racing girl Radical Racing 4
skystryd Idea Time 79 Midget Spridgets 2
SD Bugeye I have no idea Spotted 2
David Townsend For Sale Cool Father's Day Gift Idea Jaguar Classifieds 0
David Townsend For Sale Cool Fathers Day Gift Idea! Austin Healey Classifieds 0
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
69MGC General MG Vendor List web site idea MG 0
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
Lynn Kirkpatrick MGB Another whacko idea??? MG 5
catfood Any idea how to train an octupus? Austin Healey 1
PC I have no idea Spotted 5
PC don't know, but I have a pretty good idea, Spotted 0
Willie_P TR4/4A Weight Weenies: Tr4 relo of battery to boot...good idea? Triumph 6
anarchy99 Springet engine idea?... Spridgets 16
T TR2/3/3A Sticker idea; good or bad? Triumph 11
RickB Anyone doing a steering wheel swap - a little loctite might be a good idea Spridgets 2
bugedd Limited Slip advice, scrapping idea of RX7 rear end Spridgets 34
W Fun Idea Triumph 7
Geo Hahn TDC Check - Old Idea w/ a New Twist Triumph 17
rkep01 Does anyone have an idea Spridgets 15
bthompson A completely insane idea... Spridgets 17
J Good idea to seal gas tank? Spridgets 5
M another idea. will it fit Spridgets 8
Willie_P TR4/4A Custom Shock Link: idea [Tr4] Triumph 1
smaceng Bugeye...idea vs. reality Spridgets 20
angelfj1 Christmas Gift Idea for TR Lovers Triumph 12
PatGalvin Starting Engine on rolling chassis - a good idea? Triumph 25
Pythias Freaking Brilliant Idea Spridgets 14
Tr4dude TR4/4A any idea on this Tr4 camshaft? Triumph 3
Thor Any idea what this sound might be from motot Spridgets 9
M MGC Polyurethane bushings on MGC GT - Good or Bad idea MG 2
M Polyurethane bushings on BJ8 - Good or Bad idea Austin Healey 6
roscoe Useful idea? Austin Healey 5
W A great idea from the Brits Spridgets 0
lbc_newbie Aluminum valve cover - good/bad idea? Spridgets 3
M Monza Exhaust for a 1500. Good Idea? Spridgets 7
weewillie also toying with the idea of this Restoration & Tools 15
healeyboz any idea as to where a guy could get this set-up Spridgets 11
TRnorwegian TR6 Japanes TR6 starter engine - good idea or bad? Triumph 21
T How about this bright idea? TA shim gizmo Triumph 7
A Brake/Clutch Reservoir - any idea what it fits? Triumph 4
AUSMHLY Healey courtesy light...another bright idea Austin Healey 43
chicken Any idea how to make trim panels Austin Healey 5
Steve1970 driveshaft removal, here's an idea! Triumph 9
regularman Extra cooling idea Spridgets 33
TexasSprite Door liner idea for Bugeye Spridgets 5
Atrus LoO Idea for all [even those who can't attend!] Spridgets 8
regularman OK, i just had a great idea for the heat! Spridgets 7
Morris Stupid project idea... Spridgets 9
