Extra cooling idea
regularman
I think I will install this tomorrow. The idea is to give me extra cooling and move some of the heat out of the engine compartment.
tony barnhill
Great Pumpkin - R.I.P
I'm confused....do you have a rear end in your engine compartment?
Seriously, how's that gonna help?
regularman
regularman
I am gonna run some half inch copper lines from the heater box hoses with some Tees and valves through the tunnel and to that heater core back there to radiate some heat out back there.
tony barnhill
If you have excess heat why not fix the cooling system so it works optimally instead of doing all that work?
backflush engine
replace water pump
boil/clean/recore radiator & heater core
replace hoses & heater control valve
make sure air is flowing through radiator not over & under
Plus, install an oil cooler
Pythias
I don't understand the WHY of extra cooling. Does your car overheat? In my rather limited experience with Sprites, they don't NEED anything more than what the factory provided. That is you don't need and oil cooler, you don't need an extra fan, (tho using an electric and removing the engine fan will provide extra horses) and you most likely don't need an extra radiator! Its all cool to have (until you try to change your oil and mix the dirty oil from the cooler with the clean oil you just added).. I've run in 98 degree weather, stuck in traffic jams for over an hour, and climbed the Rockies at 4000 rpm in third gear and NEVER overheated.... but then my engine is a MOSTLY stock 1098. ....
regularman
regularman
backflush engine
replace water pump
New water pump, hoses, I went through the heater control valve. Radiator was a used one that looked better than the one I had. I just hate to tear all that stuff back out again. It has an oil cooler too that I flushed out and cleaned up as well as the hoses. I wanted to find a way to keep it on the road this summer. I don't know what is causing it. It seems to run nice and cool for the first 1/2 hour or so and then if I shut it off, it runs hot after that.
tony barnhill
Well, before I started running lines through the underside, I'd pull that radiator &, while you're at ir, backflush the engine.
How do you say, "DPO"? hehehehe
jlaird
Think I would try a nice new thermostat. Then would have the radiator cored along with a back flush.
blownbugeye
I'm thinking about doing the same fix. Moving some of the heat out of the engine bay is a good idea.I will be adding a small fan on a relay with temp. sending unit combined with my main rad.elec. fan to cool this aux. rad. I have cooling problems that won,t go away no matter what I do and I,ve spent alot of time on this.
jlaird
It seems to me, in days of yor, some race cars had very large water tanks attached to their systems.
Maybe Hap can weigh in here about finding the correct high quality water pump. I suspect there are some water pumps causing overheating problems due to low flow and cavitation.
Baz
Was that for colling down the fuel?
I had cooling problems too Kim, that trip back and forth to the Ozarks this time, I never went over 1/3 on the gauge.
I had the radiator out and flushed by a radiator shop, head flushed, new water pump and the heater by-passed, new t'stat and hosing; whichever one of those things worked a treat, but I suspect the water pump, as it was the last to go on.
jlaird
Maybe, just maybe we have some bad water pumps floating around. By that I mean the wrong pump for the vehicle.
Lookie two pumps Moss 434-540 948 thru 1275 12CD/H1745 and 1275 12CD/H1746 and up Moss 434-545. Moss catalog page 14 by the way. The latter seems to be standard radiator and cross flow as well.
I bet the wrong one even fits.
Long ago on a 3/4 race ford I had to have the impellers shortened on the water pump to slow down the water through the radiator so it had time to cool. Shrug, it worked.
So, I have no idea what the difference is but it could be larger or smaller and still be interchangeable in the head.
Guess I would check the pump part number.
Must be a reason.
Some impellers are made of stamped steel and some are cast, and the depth of the impellers vary.
regularman
regularman
Well, guys. This was something I figured I could hook up in a day without tearing the car back apart. I am not going to do anything that cannot be undone. Only going to cut the heater hoses and install some Tees and run those lines back there and see what it does. I probably do have a bad radiator but I want to keep driving the car for the season and then work on it this winter when off the road. I thought this might be a quick fix for now so I can keep on driving it. The lines going back as well as the heater core will all radiate some heat. I figure I am not far from keeping it cool right now as it takes 1/2 hour or so for it to get hot right now. It is a weird condition that I have. I can fill the radiator and drive in stop and go traffic and it might overheat but it takes a long time. If I run 70 on the interstate for a few miles, I can watch the heat hand steadily rise and when I stop after that it goes to boiling point. (I know where 212 is on my gauge because I calibrated it when out of the car) after that is might cool off a bit but still is near boiling and goes to boiling easily. I have not yet heated it up to where it blows steam, I usually shut it off and let it cool down before that.
jlaird
Intresting Trevor, and I bet they cool different as well.
regularman
regularman
OK, did not work on this today. My kitty cat of 15 years and friend through thick and thin took a bad turn for the worse and we had to make the hard decision and have her put down today. Spent the afternoon making a wooden box and digging a hole in some dry ground as it has been drought here. We do get attached to those little critters. Not a good day for me. Tony and jack, I hear what you are saying and I know ya'll are right. I am just trying to get by till I can get it fixed right. Its been forever on this car and I just need a little extra cooling to keep it going.
jlaird
Sorry about your loss. It's tough, no question about it.
Do what you need to do Kim, your work is of excellent quality and it is fun to follow your efforts.
SAMidget
Down here in Johannesburg
On the Spridget tour I was constantly concerned with overheating, watching the gauge is not conducive to relaxed driving. Anyway the water pump packed up and I was trailered for about 100 miles. Next day a new water pump and I noticed the diameter of the pulley was significantly larger than the old pump's pulley. The rest of the trip was amazing the temp gauge must have dropped by half. As opposed to just under the H mark, it never approached the N mark. The smaller pulley rotates too fast so it either churns the water or pumps it too quickly through the radiator. The larger pulley turns less giving the water time to cool through the radiator.
So out with your radiator back flush every and anything and make sure your water pump is the larger diameter kind, about 5 inches as opposed to about 4 inches.
texas_bugeye
what about the radiator cap. If its not sealing boiling temp is going to come on you pretty quick.maybe your not running pressurized? could be the wrong lenght spring under the cap and your sealing on the secondary ring.
T extra cooling for e-type v12 carbs ... Jaguar 1
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
R Extra 948 and 1098 Engines Spridgets 9
D TR2/3/3A extra hole in my water pump? Triumph 3
S TR2/3/3A Tr7 and a little extra Triumph 2
D TR2/3/3A Extra wire in the harness Triumph 7
PC in the movies, an MG-TF [with extra cheese] Spotted 3
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
D extra stop/brake light Austin Healey 33
D TR4/4A extra long oil filter attachment stud Triumph 9
T TR4/4A Extra carpet pieces? Triumph 9
Rob Glasgow Extra clip - Austin Healey 5
J ??Purpose of extra holes in wooden seat runner spacers?? Austin Healey 4
tinman58 TR5/TR250 Extra gaskets Triumph 3
M TR2/3/3A Extra holes in bulhead Triumph 7
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
P TR6 Extra digit in title Triumph 8
DNK Got an extra 100 Large? Lotus 3
M 100-4 BN2 Front Fender with extra Groove Austin Healey 2
JPSmit MGB, LBC graveyard & an extra Spotted 10
Banjo TR4/4A AAAAUG! anybody got an extra TR4A piston? Triumph 3
V How much extra engine oil with oil cooler??? Spridgets 5
Number_6 If I had the extra money... Triumph 11
S MGB MGB engine mounts - "extra" plate? MG 2
angelfj1 Anyone have an extra one of these? Triumph 10
G anyone have an extra front side marker lens? Spridgets 8
KVH TR4/4A TR4 Water Pump Extra Vane Triumph 7
tahoe healey extra fuse box Austin Healey 1
R ADDITIONAL FUSING FOR EXTRA PRECAUTION? Austin Healey 15
NardisCNC An Extra Wire... Please Help!! Spridgets 8
S Doc, ya gotta be EXTRA good this X-mas!! Other Cars 11
jlaird Came into a few extra dollars Spridgets 5
E GT6 Do i need to fabricate extra supports for the GT6? Triumph 9
N Maybe a little extra! Triumph 2
CCURTISS T-Series Extra MGTD/TF Clutch Actuating Fork???? MG 2
mgb4tim "MG" Key Blanks - I'll have a few extra. MG 4
mgb4tim Wedge TR7 Key Blanks - I'll have a few extra. Triumph 0
B TR2/3/3A adding extra horsepower to your TR3 Triumph 5
tony barnhill T-Series Extra MG TD Parts MG 26
tony barnhill T-Series Extra TD Stuff MG 16
jlaird Extra! Extra! Extra!! Spridgets 0
tahoe healey Extra rear light. Austin Healey 8
jlaird If you have an extra 25 min Spridgets 0
DNK SOMEBODY HAVE EXTRA TIME IN THE MIDWEST??? Triumph 4
regularman A place for extra fuse holders. Spridgets 5
P extra brake lights Triumph 10
Gray_Cat The 2 1/2" Of Extra Leg room in A Bugeye. Spridgets 2
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
T Extra Wires? Triumph 11
G Lotus super seven 1964 Extra car to buy Lotus 1
