1275 Cam Specs - Standard
pakiwi
I am going through the parts in the engine and I will be replacing the cam in the future when I get some upgrades. How do I check if the cam that I have is within specs to be used again. The points of the lobes are quite shiny, which I am guessing is due to excessive wear.
I have measured the lobes and each is 1.342 - 1.344.
Bearings are 1.372, 1.622 and 1.665.
Any help would be appreciated, or is it ready for the bin.
Cheers
Allan
Morris
The best way to check your cam is with a dial indicator https://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=623
on a magnetic base https://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=5645. If you don't already have these tools, they are pretty good to have around... and they are real fun to play with.
Basically, you put the shaft of the dial indicator on the push rod (this may require removing the rocker pedestal assembly) and turn the crank until the rod is at it's lowest point. Then zero the dial and turn the crank until the indicator reaches it's highest reading. Record said reading and repeat the process for all lobes. If all of your lobes measure within a few .001s of each other, you should be fine. Be sure to compare intake lobes to intake and exhaust to exhaust. On my car the lift is the same across the board, but yours may be different.
I will add this last piece of advice: I spent a lot of time and effort (and a little bit of money) justifying keeping my cam. At the time, I was having a difficult time finding an affordable replacement. Now I dearly wish I had chunked my cam while I had the engine out and before I replaced all my lifters. Now I need to pull my motor again and throw away all the $$ spent on lifters. So if you have the drive, time and cash, you may consider just replacing the cam now and saving yourself headache down the road.
B Installing cam bearings 1275, can I do it? Spridgets 1
bugedd what 1275 cam to use Spridgets 1
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
Rut How much does a 1275 weigh? Spridgets 8
