Sorry - related question on Bugeye comb switch
jlaird
Ho ho. combo knob is lights, Key just activates ignation.
Pull button or push button for start.
T
tdskip
Thanks Jack.
The starter button (push) works without the key, and she'll run like that until she runs out of gas.
Looks like I need to run a wire from the new fuel pump to the white wire or brown to get me to the person helping me with the lock.
After than the the fuel pump should be white ire I think.
Wiring covers are so old and tatty that it is hard to tell what is what...
drooartz
If your wiring is old and funky, I highly recommend replacing the harness with one from British Wiring
https://www.britishwiring.com/
Bugeye harness is really simple, and that way you will know exactly what you have. Took ma about a week to remove/replace, but I work really slowly when I don't know what I am doing. I'd guess you could do it In one day easily.
Bugeye starter should be a pull as well--it's a cable that runs to a switch on the firewall. There is no solenoid.
T
tdskip
I'm thinking that I'm headed that route Drew. I'm not confident that trying to 'patch' her up is going to lead to anything but madness.
T
tdskip
Another though/question here.
With my ignition key gone missing (the least of the DPO issues) I still get ignition spark without the key but the fuel pump was hot wired and recently caused a fuse to blow.
How about if I wire the fuel pump to the Brown (always hot) wire and then simply disconnect the battery when she isn't running.
I think that will work, no?
drooartz
I don't know... Tunebug still has the original mechanical pump, so no wire going there. Not sure how you would wire in the pump correctly. Might want to look at a wiring diagram for a later sprite with the electric pump, and see where the pump hooked in. The Haynes book has diagrams for all year cars, so it might help.
jlaird
Of course you could do as you suggest. Could also wire an Ace hardware switch in to the wires from the key switch that does not work and tie the fuel pump to it so all work in the on postion and off of course the other way. Just tape it all in and let it hang a bit below the dash so you can get to it easly. Cheep and dirty way to fix for the short term.
T
tdskip
Sounds like a plan Jack. Biff had the same suggestion on the other post, so I think it is a plan.
Thanks you Drew as well.
Thanks everyone!
jlaird
So nice when a plan comes together. LOL
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Rut TR4/4A Sorry Top anyone? Triumph 0
CJD TR2/3/3A Sorry...I think I cleaned out EBAY Triumph 17
dklawson Sorry... Urgent Request for Friend - Marina Front Engine Plate Other British Cars 2
dklawson MGB Sorry... Urgent Request for Friend - Marina Front Engine Plate MG 3
G Emergency...Sorry MG 19
DNK sorry... Triumph 9
TR4nut Sorry to see this show up on ebay Triumph 43
tweety sorry to bring it up again... zddp also synthetics Spridgets 2
livinginthepast self-delete | sorry, i screwed up. Spridgets 1
scubabatdan Sorry been gone awhile, finally made progress... Spridgets 11
JPSmit Registering in CA - long post - sorry Spridgets 16
roscoe Sorry, I don't know why... Austin Healey 13
angelfj1 SORRY - YET ANOTHER TIRE QUESTION Triumph 2
M A Triumph Innovation, Sorry MG MG 6
G I'm sorry, I don't normally do this....trashing VB Triumph 10
B Sorry guys, but i am new here and need the help! Spridgets 6
jaybird So sorry, can't talk now, gotta run, going... MG 40
Bruce Bowker Sorry but another eBay car MG 5
M TR6 newcomer needs help tr6 brakes- sorry long post Triumph 5
V More questions... yeah I'm sorry... Triumph 9
J sorry for this stupid question MG 9
M Heat-related carb issue on BN1 Austin Healey 7
nevets Small Healey-related tidbit Austin Healey 2
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
Michael Oritt Clutch-related noise Austin Healey 14
MisterB Do you like barn finds? [Not Austin Healey related] Austin Healey 11
Joe Reed General MG MG related arts & crafts? MG 8
S A few valve cover [rocker cover] related questions, 3000, BJ8. Austin Healey 9
Jim_Gruber Not LBC but British Car Related - Bathhurst 1000 finish- worth a look Spridgets 3
anarchy99 Hardtop question... Spridget related Spridgets 21
M Really dumb question related to turning back wheel and drive shaft Spridgets 4
glemon Business Opportunity [Not Spam, Lotus Related Lotus 4
T TR2/3/3A more timing related questions Triumph 19
M Humor me with a thought problem related to part availability... Spridgets 8
Lukens TR2/3/3A Sometimes I wonder about myself. [TR3 related] Triumph 5
GBRandy Wedge Triumph Production Numbers [TR8 related] Triumph 26
RickB Not Midget Related [mostly] Removing crank pulley Spridgets 6
J Question regarding Bugeye tach and related topics Spridgets 8
O TR6 Couple of Tr6 related questions Triumph 9
Andrew Mace Interesting little online auction-related scam? Triumph 12
T Your TR related New Year resolutions / goals? Triumph 48
T What is your least favorite related job? Triumph 43
DrEntropy Semi-car tool related. Restoration & Tools 18
UmmYeahOk Which is better - Carb Related Triumph 2
T So what are your 2010 Triumph-related resolutions? Triumph 50
UmmYeahOk Shipping heavy bulk items [triumph related] Triumph 17
T Wobble in front wheel - and related question Spridgets 9
W Interesting BE related webpage Spridgets 1
nevets paint bubble, not rust related Restoration & Tools 7
