did not use my car for 3 weeks and found a spongy brake pedal and the dash light on pedal pumped up again but have several questions
1.how do you reset the hydraulic switch if its stuck and are they available new-mine seems gummed up.
2.the light stays on even if i disconnect the wire from the switch.
3.there is only 1 wire going to the switch but it has 2 terminals.
4.If the MC is leaking backwards into the booster where would i find the fluid going-i must have a leak but cant find any fluid.
Thanks for any and all help
