TR6 Couple of Tr6 related questions
oxendine
What size Su's will fit and perform properly on the Tr6? I have a J type overdrive unit. What is the procedure to fit this unit to a non overdrive transmission?
Thanks
AltaKnight
Why do you want to change the stock ZS's for SU's?
TR3driver
Great Pumpkin - R.I.P
Fitting a J-type to a 72 is a major undertaking. The gearbox will have to be almost completely disassembled (might as well do the whole job while it's apart), and then you'll need a mainshaft that matches both the gearset in the gearbox, and the overdrive. I'm not certain offhand, but ISTR you have to order a custom-made shaft to mate a 72 gearset to a J-type. You'll also need to strip the shift cover, to drill & tap it for the funky metric threads for the lockout switch.
Most likely, you'll also need to disassemble the OD and replace the speedo drive gears with a ratio suitable to your speedometer. Another alternative is to have a ratio adapter made to suit. But frankly I'd want to strip and examine the OD anyway, even a "working when removed" unit can have serious internal problems that are much better to find now rather than after it's in the car.
Then you'll have to cut the frame, and create a new rear mount for the OD. One successful method is described at
https://www.buckeyetriumphs.org/technical/jod/AdaptingJOD/AdaptingJOD.htm
HS6 SUs seem to be a popular choice, but you'll still need to get suitable needles and springs. Depending on the carbs, there is also some work required for linkage, I believe.
O
oxendine
I guess I'm a little confused as to the fitting of the overdrive unit to a Tr6 transmission. I bought the unit from a forum member who said it was from a TR6. I thought or maybe wished it would be as simple as bolting it to the transmission?
Seems I'm wrong?
TR3driver
The overdrive changed a great deal in 1973, from the earlier A-type to the J-type. Although the overall operation is similar, the J-type is very different internally (ISTR one of the bearings is the same, but everything else is different). The mountings, speedo drive, mainshaft etc. all changed at that time as well. The J-type uses a much longer adapter, so its body sits much farther back in the car (hence the cuts to the frame to mount a J-type in an earlier TR6).
But even installing an A-type is not as easy as just bolting it to the transmission. The mainshaft still has to be changed from the long non-OD version (which runs all the way through to the rear flange) to the short OD version (which ends at the overdrive gears), and the countershaft has to come out in order to remove the mainshaft.
And you still need the lockout switches (two of them for an A-type) on the top cover. Backing up with overdrive actually engaged does some serious damage to the unit, so the lockout switches are essential to prevent it from being engaged in reverse.
tdskip
Did you buy the whole transmission or just the overdrive unit? Sounds like the later. Pretty common to do that with an idea you can just bolt it on, but not the case. Randall nailed it.
On a '72 might be best to just sell that unit and take the money and put it towards a correct A-Type.
T TR6 Couple of rare TR6 options Triumph 9
AngliaGT Lotuses,Loti,er a Couple of Lotus? Spotted 4
AngliaGT At a couple of Car Shows in SW Virginia Spotted 3
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
AngliaGT MGB-GT Couple of Dumb Questions - '67 GT MG 11
AngliaGT A Couple More Spotted 0
K TR2/3/3A Couple of choke questions Triumph 1
S TR2/3/3A TS27036 for a couple laps Triumph 13
D BT-7 couple of general questions Austin Healey 6
D Lilly Engine Latest / couple of questions Austin Healey 34
T TR2/3/3A Is there a timing cover seal that will last more than a couple of year? Triumph 23
G TR4/4A A couple of engine rebuild questions... Triumph 8
matmire couple of Healeys in this Stella Cidre commercial Austin Healey 2
Steve A couple of bikes that my dad designed British Motorbikes 8
M TR4/4A Dash instruments.......couple of questions. Triumph 5
5 Couple of Spridgets for sale Spridgets 2
gbtr6 TR6 Couple of general resto questions Triumph 4
J TR2/3/3A A couple of questions. Triumph 13
PC last couple of days Spotted 2
M Help me ID a couple of bolts on my 1275 engine... Spridgets 5
BobMunch A couple Questions about later Midget heater cores Spridgets 0
J true value of a couple of books... Triumph 13
O TR2/3/3A TR3 Wheel Studs, Couple of Hinges Needed. Triumph 2
RickB Couple qyestions - plate light plinth Spridgets 3
T TR2/3/3A A couple TR3 body questions Triumph 4
AngliaGT A Couple of Tempting Deals MG 4
jackq MGC PLz save a couple of MGCs MG 6
T A couple of clutch questions Triumph 9
P A couple of TR# questions Triumph 26
theleisure A Couple [unwanted] Firsts... oil & temp Spridgets 6
T TR4/4A Lightening a TR4a flywheel - a couple of questions Triumph 7
S Couple pictures needed Austin Healey 5
livinginthepast Signing off for a couple months... Spridgets 7
VelodromeRacer A couple of vids from the KIC and Grattan Racing 1
GBRandy Wedge I was bored...a couple of TR8 pics Triumph 16
RickB A couple items I have For Sale Spridgets 0
Strapping_Lad I found my new baby! WTB a couple parts Spridgets 19
D New to MGs w/ a couple questions MG 16
RickB Anyone got a couple of these to share? Spridgets 2
S Alpine a couple steps closer to running Sunbeam (Rootes) 4
JPSmit couple of interesting cars on ebay Spridgets 5
John_Mc Couple of unique LBCs on CL Triumph 7
JPSmit Couple of things for sale Other British Cars 2
mrv8q Couple ZS 175 questions Triumph 9
Baz Couple more pics..... Spridgets 6
walshja couple of questions Spridgets 16
motofiaccone Project start and a couple questions Spridgets 15
Shealey Need a couple things... anyone? Spridgets 10
Adam58 A couple of English Fords needing adoptive homes Other British Cars 1
