A Couple [unwanted] Firsts... oil & temp
theleisure
Bronze
It seems as if everything is pointing me towards installing the 1275 i have sitting in the basement. Yesterday I experienced a couple firsts while driving my 1098. I love that motor and it's been great until recently (with the starting issue as you may recall). When I rolled up to a stop sign yesterday the oil pressure gauge, which usually reads 20-25 at warm idle, went all the way to 0 (zero!) for just a moment and then back up to 20 right away. This happened again 1 time later in the day too. I also saw the temp in my car indicate over 190 in stop and go traffic for the first time ever yesterday. Within 20 minutes the warm idle pressure was about 17. Oil level was a little low but definitely not empty.
If I put the 1275 in for a little while now (it's condition is pretty much unknown but I got it from somebody that has had a few sprites and he said it was in good shape) what do you think the issue is and what should I do to freshen up the 1098 while it's out? I don't have the money for a full overhaul so what should I look for and what is the best case scenario?
barf
mightymidget
Check compression wet and dry
Do a coolant system test, look for radiator condition inside and out
Change your oil and filter
Check timing, gap, point
Your symtoms do not sound like your motor is need of overhaul, You would have low oil pressure all the time at idle, and the 190 degree temp seems well within operating range. If anything I would think maybe your oil pump is wearing or oil filter issues, could even be some sort of blockage in a oil passage way.
Is motor lighty knocking when pressure drops or at any other time? do you have excessive smoking?
also if you do not have a bafle in oil pan and you are low on oil with a sudden stop you pickup could have caught some air causing a temporary loss of oil pressure
Billm
Whether you have a bafel in the oil pan or not if you are down more than a half quart of oil you will see this. It happens when you pull a fairly high-G stop and the oil sloshes to the front of the pan and the pick-up is at the back. It happens to all of us but does no real harm if it recovers pretty quickly (2 to 3 seconds). I wouldn't worry about it- it is just your car's way of telling you to check the oil level.
Keep driving it!
BillM
tdskip
That would have prompted some colorful language on my part. Can you let us know if it does it again with the oil topped off?
jlaird
I would also think low oil.
texas_bugeye
remember that little pump sit's away up on the tail end of the cam shaft. Most low volume high pressure pumps like to operate under a flooded condition ours are up out of the sump and tiny and expected to deliver a fair amount of pressure so a minor loss in head oil level shows up mine will loss a few pounds when a quart down. My guess is pump wear/ oil level.
theleisure
theleisure
Bronze
Ok, here's an update: I added half of a quart of oil (20w 50 as alway) and went back to the radiator cap that I was using until about a month ago. It seems to have done the trick. I drove to work & back (12 miles round trip, 30 minutes each way) and to the grocery store without any issues. I'm going to do an oil & filter change this weekend on the 1098. That'll give me the chance to take my time rebuilding the carb & cleaning up the 1275.
Thanks everybody, I was really freaking out about this one
AngliaGT Lotuses,Loti,er a Couple of Lotus? Spotted 4
AngliaGT At a couple of Car Shows in SW Virginia Spotted 3
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
AngliaGT MGB-GT Couple of Dumb Questions - '67 GT MG 11
AngliaGT A Couple More Spotted 0
K TR2/3/3A Couple of choke questions Triumph 1
S TR2/3/3A TS27036 for a couple laps Triumph 13
D BT-7 couple of general questions Austin Healey 6
D Lilly Engine Latest / couple of questions Austin Healey 34
T TR2/3/3A Is there a timing cover seal that will last more than a couple of year? Triumph 23
G TR4/4A A couple of engine rebuild questions... Triumph 8
matmire couple of Healeys in this Stella Cidre commercial Austin Healey 2
Steve A couple of bikes that my dad designed British Motorbikes 8
M TR4/4A Dash instruments.......couple of questions. Triumph 5
5 Couple of Spridgets for sale Spridgets 2
gbtr6 TR6 Couple of general resto questions Triumph 4
J TR2/3/3A A couple of questions. Triumph 13
PC last couple of days Spotted 2
M Help me ID a couple of bolts on my 1275 engine... Spridgets 5
BobMunch A couple Questions about later Midget heater cores Spridgets 0
J true value of a couple of books... Triumph 13
O TR2/3/3A TR3 Wheel Studs, Couple of Hinges Needed. Triumph 2
O TR6 Couple of Tr6 related questions Triumph 9
RickB Couple qyestions - plate light plinth Spridgets 3
T TR2/3/3A A couple TR3 body questions Triumph 4
AngliaGT A Couple of Tempting Deals MG 4
jackq MGC PLz save a couple of MGCs MG 6
T A couple of clutch questions Triumph 9
P A couple of TR# questions Triumph 26
T TR4/4A Lightening a TR4a flywheel - a couple of questions Triumph 7
S Couple pictures needed Austin Healey 5
livinginthepast Signing off for a couple months... Spridgets 7
VelodromeRacer A couple of vids from the KIC and Grattan Racing 1
GBRandy Wedge I was bored...a couple of TR8 pics Triumph 16
RickB A couple items I have For Sale Spridgets 0
Strapping_Lad I found my new baby! WTB a couple parts Spridgets 19
D New to MGs w/ a couple questions MG 16
RickB Anyone got a couple of these to share? Spridgets 2
S Alpine a couple steps closer to running Sunbeam (Rootes) 4
JPSmit couple of interesting cars on ebay Spridgets 5
John_Mc Couple of unique LBCs on CL Triumph 7
JPSmit Couple of things for sale Other British Cars 2
mrv8q Couple ZS 175 questions Triumph 9
Baz Couple more pics..... Spridgets 6
walshja couple of questions Spridgets 16
motofiaccone Project start and a couple questions Spridgets 15
Shealey Need a couple things... anyone? Spridgets 10
Adam58 A couple of English Fords needing adoptive homes Other British Cars 1
Tinkerman A Couple of Chrome Replating Questions. Triumph 5
