TR4/4A Lightening a TR4a flywheel - a couple of questions
tdskip
OK - once more with feeling. I found an experienced local speed shop that lightens flywheels on a regular basis. They aren't going to touch mine until I bring them the reference picture below. What is a <span style="text-decoration: underline"><span style="font-weight: bold">safe</span></span> target weight for removal that will make her a bit more snappy in acceleration and gear changes but not compromise her practicality on street use. Is there a weight range that is a good balance?
BTW - here is the image out of David Vizard's reference material
TR3driver
Great Pumpkin - R.I.P
I believe Joe A. recommends 14# for the street.
My alloy Fidanza is quite a bit lighter than that (under 10 I think), and the car is still very streetable. Takes just a little extra care to keep the rpm up when launching; usually the time it gets me is when I'm just puddling around and not in a hurry. You can't just take your foot off the clutch as with the original flywheel.
TR4nut
Actually I thought Joe was closer to 17-18#, at least for the TR4.. I bought one from him a couple of years ago. 14# sounds too light offhand but my memory may be flawed.
Edit: thinking about it, we may be talking about the same weight depending on whether the ring gear is taken into account or not. Bottomline, I think the max removed safely on the flywheel is roughly 10 lbs.
T
tdskip
So if I have them follow the above diagram and tell them no more than 8 pounds do you think (no guarantees I know) that gives me safe harbor?
Thanks guys - lots to learn here.
TR4nut
Just my opinion Tom, but yes I think you'd be okay. The FOT archive talks about a 28 lb flywheel going to 24 very easily, and 18 lbs with a little more work.
TR3driver
I looked back through my notes; Joe was talking about a new, lightweight steel flywheel at 14# for street & autocross, 9-10# for racing. This is the bare wheel, not including ring gear (he also had some lightweight ring gears made) or clutch.
<span style="font-style: italic">I feel there is a market for a STREET VERSION of a TR4A flywheel. I propose the weight to be about 14#s.
Unless you are a 'racer', 9-10#s is a bit light for the street. For street and autocrossing 13-14#s may be better. </span>
A real work of art:
T
tdskip
Thanks Randall - that is a thing of beauty.
There is appear to be some concern over the safety of lightening a 30+ year old flywheel. Not knowing any better are there any risks here that folks considering this need to be aware of?
TR3driver
Well, of course the major risk is that the remaining metal will not be strong enough to withstand the forces involved. The centripetal force trying to tear the flywheel apart goes up with the square of rpm. Explosions, while rare, do happen, but mostly at rpm well over the factory redline.
But you should be OK at 8# removed, as long as you don't go too wild on rpm.
K TR2/3/3A Lightening a stock TR3A flywheel..... Triumph 13
A Lightening the Sprite Spridgets 14
T Lightening BN1 Flywheel Austin Healey 5
vping MGB MGB Flywheel lightening MG 6
T TR4/4A tr4 engine block lightening-how much? where? Triumph 5
T block lightening-tr2,3,4- how much-where Racing 22
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
