I found my new baby! WTB a couple parts
Strapping_Lad
Member
I drove her back, Tucson to Las Vegas, last Saturday with out a single problem. A great '62 Midget that has been all sorted out and has a rebuilt 1275 and trans. The PO owned the car since '88 and has every service record since then. I now have about a hundred invoices from O'Connor Classic in San Jose. Mechanically the car is great, everything works, well... the speedo went out on me at the end of the trip. I guess it wasn't prepared for prolonged use.
So I WTB a new speedo for her, but the gauges are half smiths half jaeger. I would like to get all Jaeger so I would need a Jaeger speedo and mechanical tach if anyone can help me out with that.
Ok ok, I'll give you a couple pics too! :smile:
Cable may have just fallen off the speedo.
Nice looking car. Any pics under the bonnet?
drooartz
Very nice. Sidescreen cars really are my favorites. Glad the trip was (mostly) uneventful. Enjoy the drives!
Jim_Gruber
Other option pending a rebuild of the speedo would be a Digital Speedo using a Bicycle Computer. A wired not wireless Sigma 1200 goes to 180 mph, < $25.00. Sigma 1600 is backlit for night driving, a little more expensive. I used a round 1" hobby magnet JB Welded to the outside of the DS Drum, an upgraded magnetic reed switch from local electronics shop that attaches to the spring mounting plate for the rear axle, and a homemade bracket attached to the mirror mount bracket that puts the digital readout on top of the dash directly in drivers line of sight. A fun engineering project and speedo is absolutely right on every time. Speedo, wires, magnets, upgraded reed switch came to < $40. Details available.
jaegzie
Jaeger gauges are fun to come by for these. Unless someone can point you in a better spot. But seeing as my last name is Jaeger I like to grab these when I can and have them in several of the healeys. They are getting a little harder to come by but and unfortunately the best place lately I have found for them are on ebay. Unless you can find someone with a extras, if you do let me know also.
Strapping_Lad
Strapping_Lad
Member
Sorry, no shots of the engine bay or interior yet! Will do it this weekend.
The bay is not detailed but it is a driver. The engine is nice and clean with no wet oil spots. :smile: The interior is really nice with good seats and carpet.
I took the speedo out yesterday, took it apart, lubed it and put everything back in and still didn't work.
jlaird
Is the cable turning??
jvandyke
Nice car. My '63 looks very similar. I noticed the grill badge is red. Mine was too until I put a black on it this winter (because I though black was correct and looked better) maybe not?
Yours does appear to have front parking light syndrome though (fenders from different years with different light placement).
Great looking ride.
I'm jealous of your 1275 though. Mine still has her original 1098.
A very nice car indeed!! :smile:
It's another case of high/low turn signals too.....and I think the headlight trim rings are different.
RickB
I've got some gauges in my 64 MKI I could take a couple pictures when the weather clears.
scoutll
Jeff, The black and red is correct. The all red emblem was later. Don't quote me, but I think late 67 or 68 on the Midget.
Strapping_Lad
Strapping_Lad
Member
Well I had a chance to go through one of the boxes of extra goodies. I found all the other original gauges in there. Jaeger tach and oil/temp and a couple different aftermarket amp gauges. Along with that discovery, I found the smiths tach it was replaced with is electric and not mechanical as it should be.
Yeah, I noticed the different blinker height but its not really something I am going to worry about now. I'm just happy they both work! :p
Sarastro
Looks and sounds like a really nice midget.
There really isn't much that can go wrong inside the speedometer that will stop it working completely. The pointer can come loose (it's just a press fit), the pivot for the aluminum cup can get some dirt in it and bind, or the shaft can jam, causing the cable to break. Usually the problem is a cable or drive gear, which is easy to check: see if the cable is moving when the car moves. You can also put a screwdriver into the cable connection on the speedo, spin it (counterclockwise) and see if the pointer and odo change.
Knowing next to nothing about Spridgets - my "education" coming from reading this forum! - I've read here that it has been speculated that some cars may have actually been "born" that way. I am sure more knowledgeable minds will comment.... :smile:
Strapping_Lad
Strapping_Lad
Member
I keep finding all sorts of goodies in the extra boxes. There is an old Polaroid from when the PO fist bought the car in '88 with a replacement fender on the passenger side. Guess we can put the mystery to rest!
jaegzie
My 69 sprite has the same fender since for sure 77 (parents bought it) and my Dad has hated them ever since because the two lights are at different heights which makes the bumper look bent. He had the car painted and then someone pointed it out to him, and it still bothers him to this day.
Ive noticed on a few other sets of fenders that there seem to be two different heights, these all can not be replacement fenders.
Fender changed in late '69 or early '70 when the BL face lift cars were introduced. The change occurred with the thin front bumper, split rear bumper, black sills, etc.
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
mezy Just found this on ebay UK, Other British Cars 1
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
DrEntropy MGB And now, NO ARP head studs to be found! MG 13
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
Rob Glasgow Found Original Owner Austin Healey 2
J Walnut veneer for the dash, Look what I found! Austin Healey 12
2 TR2/3/3A Headache: Magnaflux found a crack Triumph 5
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
B Lost & Found FORUM Navigation Questions 3
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
AngliaGT MGB I think I found the Cause MG 5
1 MGB Found the leak, now what? MG 11
C MGB Found this spring in my gas tank MG 8
jackq MGB MGB Roadsters with a V-8 found. MG 1
M General TR Found on Google books Triumph 0
J Found something new on a Healey engine Austin Healey 3
Michael Oritt Strange debris found in sump Austin Healey 19
J Found a 1963 BJ8, by the serial number, built in October of 63 Austin Healey 26
jackq TR2/3/3A TR3s found Triumph 5
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
PeterK General Tech I've found the light Triumph 8
Number_6 TR2/3/3A TR1 Prototype found Triumph 2
K TR4/4A Look what I found in a 4A oil filter? Triumph 14
Patrick67BJ8 Healey Abbott Found Austin Healey 8
M TR4/4A More Commission Number Questions. Mine is nowhere to be found! Triumph 6
drooartz Finally found one Spridgets 8
anarchy99 Found the only other British car at the show Spridgets 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Finally found a RWA Midget Spridgets 1
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
LarryK Found MK2 parts in cavern. Jaguar 3
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
H Aston Martin DB4 converible found in UK awhile back--what was paid for it? Other British Cars 0
CLEAH Found another number on my frame [BJ8] Austin Healey 6
PAUL161 Found My old 60 midget engine Racing 6
J Found an oil leak Austin Healey 7
J Found an E Type in a Barn. Bought it. Let's Make it Run Jaguar 15
germanmichel Horror story what I found below the battery... Austin Healey 9
RickB Found on Craigslist - 2 Midgets, one is RWA for $600 Spridgets 1
C Mystery Parts found in intake. What are they? Austin Healey 21
J Funniest thing you found working on your car Austin Healey 32
RickB Found this on Ebay - NFI Spridgets 2
YYCDave TR2/3/3A Lost Triumph Found Triumph 5
Jim_Gruber So who has found Basil's Holiday surprise? Spridgets 8
Boggsy64 MGB Found parts at local auto store MG 4
J TR2/3/3A Found my overflow problem from the radiator , Triumph 9
Gliderman8 TR6 Oil Leak found! Now what? Triumph 26
