So Ellie (our MGB) is Carla's daily driver to get to and from university. I use our truck for work where I travel a lot. One vehicle makes for a NIGHTMARE!! Ellie has let us down again and I'm not enough of a mechanic to "for sure" sort this out...HELP!!
The water temp has been running at "normal". Yesterday it ran at about 1/2 way between normal and hot. This morning it spiked at "hot" after a short warm-up. Antifreeze is good. I started her up this afternoon and she immediately started going up in temp to normal and then climbed on up. There appears to be some "hissing" sound and I think the water pump may be toast. I REALLY need to get this sorted out quickly. Any suggestions or should I just order a water pump?
Another big problem is the prior P.O.s who took the data plate off of the engine so I don't know for sure which one we have :frown:.
