Which is better - Carb Related
UmmYeahOk
This GT6 MkI block is confusing me to no end. First the bearings are the wrong size (apparently they used different cranks, and not my metering needles are wrong too. My husband discovered that my Zenith Stromberg carbs are not the original MkI ones. He claims they are from the MKIII (from the part number stamped on the original metering needle that was removed.
Question is, which is/was better? New or old? Naturally I would assume the new is better, but I know they had less HP due to emissions. How much more performance would you say this MKIII carb would give me? Or is it like the whole webber deal where no one really knows, and it only matters if its brand new out of the box, or rebuilt. (which it will be anyway)
martx-5
Which is better??...in my opinion, SUs. :thumbsup:
tdskip
Unless you are really hopping uo the engine healthy ZS carbs should be just fine. Really easy to rebuild as well, and if your bushings are good cheap too!
M Better carb heat shields to deal with vapor lock? Spridgets 18
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
John Turney Need a Better Demister? Austin Healey 5
S TR2/3/3A understanding the float and needle set up better Triumph 6
Michael Oritt Towards better brake performance.... Austin Healey 28
2wrench TR6 Help with points and condenser on '74 TR6 -- or better, choices to get rid of 'em. Triumph 25
C A better sound for a Miata? Other Cars 0
C runs better without air cleaners?? Austin Healey 19
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
Got_All_4 General Tech Different style synchros which is better Triumph 4
Pythias Back and Better Than Ever. Spridgets 7
JPSmit Sometimes it is better to be lucky than good Spridgets 15
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
RedTR3 TR2/3/3A New is better? Triumph 14
B Everything runs better with this mod - all models!!! Spridgets 7
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
JPSmit Ms Triss is better not best Spridgets 14
glemon Better Move Fast Spridgets 4
bugedd Better hurry if you want your master sleeved Spridgets 12
Got_All_4 Wedge Now that's better ! TR7 brakes Triumph 1
Mickey Richaud Ain't Nuttin' Better! MG 7
C OT - Are Alfa's better? Triumph 19
Nelson Better than cardboard? Spridgets 52
TR6BobNF Big Old Cat - Better Pics Jaguar 5
PC They couldn't do better than....? Other Cars 25
BugeyeNJ58 Need a Better Muffler for 59 Bugeye Spridgets 5
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
Gundy heeding my better's advice Spridgets 162
MCNX_BFF Triumphest 2010 pix --Better late than never? Triumph 4
J TR4/4A Better TR4 Valve Cover Replacement? Triumph 8
DNK Better Tail Spotted 4
M Better head gasket for a 1500 Spridgets 26
I Bugeye-better to have negative or positive ground? Spridgets 17
JPSmit OT but sometimes it's better to be lucky than good Spridgets 9
billspohn Better Than Snow Tires MG 9
J Need a better fan Racing 0
Hap Waldrop Beer run pics, better late than never :] Spridgets 6
T Would this maybe be a better path to take? Restoration & Tools 15
M TR2/3/3A How do you get a TR3 to ride better? Triumph 19
jaegzie Which way would be better -- Body Work Spridgets 5
T 30 minutes of clean up and much better Triumph 19
Stick Car runs better with vacuum leak? Spridgets 4
healeynut My A90 Atlantic is better than your SP250 Other British Cars 10
T How can I get better fuel efficiency Jaguar 15
T Speaking of O2 sensors... two better than one? Triumph 18
lbc_newbie someone better jump on these!! Spridgets 5
R Better to be lucky then good!! Spridgets 4
Pythias Better---FINALLY! Spridgets 9
TRnorwegian Japanese gear box better? Triumph 29
