30 minutes of clean up and much better
tdskip
Time to rebuild the carbs, and with all the money flying out the door on other tasks I decided to start rebuilding them myself.
All I did to the one on the right was the clean it well and then spend about 20 minutes with some compound on a polishing brush on a Dremel.
It needs more polishing still but I was pretty shocked at how well it cleaned up.
I think the carb body is going to be much more of a challenge simply due to the surface being more complex.
Brosky
Tom,
Even if you have them professionally polished, you will still need to buff them up periodically. I had my originals apart back in the 90's and they aren't that bad at all, especially with the Buckeye advice available. I did get Jeff Palya to do my triples.
T
tdskip
I would have loved to use Jeff, and I'll probably mess them up bad enough to need to send them off anyway LOL.
What do you use to polish yours Paul?
Bob_Muzio
Tom, I like Mother's Billet polish. It comes in small jar with a large price ($14), can be found at Pep Boys but is better than others I've tried (even the metal polish sold by Griot's Garage).
Bob
TR6BILL
Ditto on the Mother's. Great stuff. A polish job will last for many months......
poolboy
You can do it. There's really not much to it and you have the most noticeable part polished. So for about 100 dollars vs what a pro charges including the time they spend shinning them up, you'll come out way ahead dollar-wise.
A couple of things to keep in mind. Unless the needles are bent, don't bother replacing them. They are tapered and can be adjusted in the RARE event that there's any wear.
Avoid the Grose jets
And get new Throttle Bypass Diaphrams (Moss # 365-745) for about 12 bucks apiece.
VB sells a nice rebuild kit sans the TBV diaphram. Their #3-953 @ about 30 bucks each.
And when replacing the air valve diaphrams, be aware of the locating tabs on the diaphrams and the corresponding slots on the air valve and the carb body.
One more thing; if you do replace the throttle shaft bushings try to save the brass caps. Even though they are included in the kit, new ones may not fit back over the bushings as well as the old ones.
Good luck and after you DIY you'll have a better understanding of what's going on in there. Oh yeah, do one at a time.
T
tdskip
Thanks guys, and yes I do dig knowing how these things work.
Do the Throttle Bypass Diaphragms always need to be replaced, just a good practice?
Any ideas on how to polish the carb main body? Cone shaped buffer on a drill? Other/better ideas?
poolboy
The TBV diaphrams get kind of brittle over time and loose flexibility. Have a look at yours; you might be ok for a while, but they have to be flexible to function properly.
T
tdskip
Poolboy - I just checked the Throttle Bypass component on the carb I took apart (just one at a time - see guys, I can be trained) and sure enough it was tripped to heck.
I also backed the idle screw off and yep, that is why the throttle disk was letting daylight through.
Is this the right Moss part for the float bottom plug?
366-070 $9.95 PLUG, float chamber, nylon & brass C3337 thru 3771
Learning a bunch here guys - thanks!
davidk
Tom, if you're still awake, TRF has their carb rebuild kits as the deal of the day until 8:00 in the morning...
T
tdskip
Hi David - thanks for the heads-up. I already have a rebuild kit, but that would have been a score! Thanks for passing it along.
AltaKnight
If they're the original Throttle Bypass Diaphragms then they are just about always hard as a rock and likely holed through so take a look, they do improve the idle when they are working.
MCNX_BFF
Wow, Tom!
Amazing what a little compound/Dremmel can do. Looks fantastic! I honestly didn't know the carbs could shine up so nicely...thought the drab, matte coloring was the way they were! :blush: I think I will give that a go!
Brosky
Fuel pumps can be made to look really good too, but this was NOT done by me and my Dremel. You can see the screws in the shine of the bodies.
T
tdskip
Assuming I get the carbs squared away the pump is next. You can get maybe 70% of the way to that shine by hand and with a Dremel, but nothing beats Jeff's process.
Brosky
Tom,
That was done by Jeff Schlemmer at Advanced Distributors, using the same methods that he has available for the distributors that he rebuilds. The last batch were done by Jeff Palya at Micropolishing, LLC.
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT Went to West Virginia Today [For about five minutes] Spridgets 2
cpbol Sharing story - Solving issue of starving for fuel after running for 10 minutes Austin Healey 67
19_again MGB Stalling and then restarting after 4-5 minutes MG 32
aeronca65t A few minutes of in-car video from Watkins Glen -Oct 10,2014 Racing 5
HealeyRick T-Series How to Build a MG-TD in 3 Minutes MG 1
aeronca65t Last 12 Minutes of the Bathurst 12 Hour Racing 0
bobh Changing Transmission Oil in 10 minutes Triumph 8
DrEntropy Within about ten minutes. Spotted 0
jackq MGB-GT FOUND>>>on the way in a few minutes MG 14
aeronca65t Jeep Disassembly-4 Minutes Other Cars 1
T Woo-Hoo! Three minutes and 26 seconds! MG 5
Gundy 5 minutes of fun Spridgets 13
BIBBER LOVE TO DRIVE MORE THAN 10 MINUTES!! Jaguar 18
drooartz Had a few minutes Spridgets 8
jaybird 35 minutes at the post office... MG 58
Hegg Elan +2 -- Headlights don't come on for 3 minutes Lotus 2
P MGB My 1st MGB - coughing after 10 minutes MG 9
B Wedge TR7 on eBay, 30 minutes left. Triumph 4
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
tr6nitjulius For Sale TR6 working/clean parts 4sale Triumph Classifieds 0
Basil Easy way to clean fuel injectors (out of car) Other British Cars 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
T How do I clean sand out of a ring & pinion? Spridgets 2
BoyRacer How to clean a cloth wiring harness Austin Healey 14
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
JimLaney Media blasting engine parts - How to clean? Spridgets 5
D TR2/3/3A Exhaust manifold clean up. Triumph 6
I General TR Mold clean up suggestions Triumph 4
S TR2/3/3A overdrive transmission, cosmetically clean Triumph 12
R General TR Best way to clean unpainted parts Triumph 1
jaegzie Cylinder wall has some build up. Need to clean. Spridgets 4
NutmegCT Cooling system clean/flush Restoration & Tools 11
T TR2/3/3A Is there a way to take apart and clean/repair TR3A headlight dimmer switch? Triumph 8
nevets How to clean a E Z Bleed ? Restoration & Tools 11
C How to clean a Lucas Headlight? Restoration & Tools 5
R did a little clean up today Triumph 5
D Best Way to Clean Corrosion on Fuse Clips. Jaguar 3
Darrell_Walker Fuel tank - just clean, or clean and seal? Triumph 15
bighealeysource How to clean aluminum shut face finishers ? Austin Healey 9
T silcone clean up Triumph 9
Moseso Mini ! Clean! Also, heavily customized ! Spotted 2
bighealeysource How to clean up rear backlight on factory hardtop Austin Healey 11
BugeyeNJ58 Garage Clean Out-1100 Engine and 4-speed Trans. Spridgets 5
K TR2/3/3A Best way to clean TR3 Bakelite horn button? Triumph 8
Rut Transmission clean up Restoration & Tools 5
W Garage clean up Spridgets 0
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
J Paint help! [I've got a mess to clean up] Triumph 9
