Something not to do on Friday driving home
Norton47
or perils of having a daily driver.
https://s225.photobucket.com/albums/dd50/Norton47/TR6%20Accident/
Hard to win a braking contest with ABS equipped vehicles. Remember to mind your following distance. Good weather day, smoothing flowing traffic, no slow downs early Friday afternoon.
Chev pickup locks up in front of me to the point of stopping. I was unable to respond quick enough. Praise the Lord I escaped with no injuries. However my daily ride did not.
Appears the frame, running gear and aft the fire wall escaped except for the cowl and the brake pedal.
Looking for parts or a whole car as this has been rebuilt from the wheel bearings up. Glad I had not done the paint.
Had not been visiting as I have been busy with setting up a Norton repair and restoration business and the 6 was running great. Guess I be around more for awhile.
I see lots of visits to my photobucket account for the photo's on window fitting the last few days. Let me know if I can provide any information if those hits are coming from folks here.
Cheers
DNK
Mark, glad to hear you are alright. Bummer about the car. Is the spit finished?
Looks like plenty to do there.
N
Norton47
Don
Not much progress on Spit. Pulled the front suspension off and had powdercoated. Stalled out on trying to make my mind up on redoing the fire wall and paint the frame with original color or to just leave as is and spray can or rubber undercoat the frame and get on with things. The 6 may come after the Spit now. But not having a daily driver is cramping things. I was going to try driving the shhhh MGB but the rear spring sag is bad so need to fix that. BPNW is out of stock on rear springs so delivery by this week end is now out of the question.
Sigh. My garage is absolutely stuffed as I had to move the motorcycle shop before my shed was done. So working in the drive way. Guess I will have to get the garage done then start on a car. At least the weather looks good for the week end.
TR3driver
Great Pumpkin - R.I.P
And check how well your brakes work under panic conditions!
I make a point to check mine occasionally; few months ago I realized that the rear brakes weren't doing their part. Pedal felt fine, no noticeable difference in ordinary driving, but in a simulated panic stop (in a deserted industrial area) I simply could not get the rear wheels to lock.
Turns out the wheel bearing housing was loose (!), and allowed some differential oil out into the brake drum. Not enough to drip on the ground, just enough to ruin the brakes.
Brosky
Sorry to hear about the car, but happy that you are OK. I can only say, I've been there, so I know the pain, though I had to sit and watch someone slide into me with no where to go, rather than me hitting someone else.
eejay56
I'm glad to hear that you weren't hurt but what a shame about your 6.
justin_mercier
Glad to hear you're OK.
Yesterday I had a close call in my 6 and braking. Driving up RT1 to foxboro to get supper at Olive Garden after work, someone infront of me slammed on their brakes. Thankfully I had enough distance that I was able to stop in time, but it also showed that I've got a brake problem too. Under normal driving conditions my brakes seemed to be just fine, but when i really had to put them on hard, while going high speed, the whole car pulled hard to the left and I was afraid I was going to lose control for a minute there.
Yet another thing to look into when i start pulling this baby apart this winter to replace the frame.
TR4A_IRS
There is a good chance that this has nothing to do with your brakes. When you are hard on the brakes, problems with suspension, and tires can make themselves well known. Your symptoms could reflect a worn shock, or some worn bushings in the front suspension. There could also have been a crown in the road that caused the car to pull left.
If I were in your shoes, I would try and replicate the braking conditions (safely, of course) on different roads and see if you get the same response each time. Based on your testing, you should be able to better diagnose if you have a problem or not.
/ back on topic...
TR3driver
I bought a TR3A that had a similar complaint; turned out that one of the front suspension pivots had ripped out of the frame.
NickMorgan
Wow, sorry to see what has happened to your TR6. Glad you are OK and the car could have been worse. Certainly looks repairable, but it is amazing how many smaller components such as the windscreen wiper, carburettor and valve cover stud have suffered. I hope you made a good mess of the truck as well!!
V
vagt6
Great that no one was injured.
I truly hope that threads like this one serve to remind us all that our antique cars should be thoroughly inspected on a regular basis for key system safety.
Suspension; braking; electrical, fuel delivery: all major systems in good nick. It's not that hard to do, and most certainly, it's worth every penny to have a professional do it for you.
Safe, not sorry.
Be safe out there, friends . . . :yesnod:
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
T MGB Quick question about something that don't really matter just want to know. MG 9
Simmo TR2/3/3A Something is eating away at my Piston Liners Triumph 15
V MGB Mystery fastener from '66. Did I miss something? MG 6
K TR2/3/3A The latest "It's always something." Triumph 8
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
Sherlock Something Swedish... Something German... Spotted 3
PC something really cool, and a Ferrari Spotted 11
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
JPSmit and now for something completely different Spridgets 8
GeorgetheTR3 TR2/3/3A Bonnet popper, or something like that. Triumph 5
AngliaGT Something Different Spotted 3
JPSmit Worth Something Somewhere else Spridgets 7
Got_All_4 General TR [TR6] Fortunately For Something to Live Something must Die Triumph 1
J Found something new on a Healey engine Austin Healey 3
2 TR2/3/3A Something's burning Triumph 13
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
bcliff MGB Are you looking for and MGB Roadster or maybe something else. MG 5
Jim_Gruber Something weird electrically with Bugsy Spridgets 7
Got_All_4 TR2/3/3A Need measurement from front to rear axels something weared happened today Triumph 7
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
B Valve Cover Plate Rivets: Useless junk or am I missing something? Austin Healey 10
David Townsend TR2/3/3A And now for something completely different Triumph 2
steveg Learned something about rear axle seal Austin Healey 3
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
DrEntropy Something happy-sad... Racing 0
V TR2/3/3A Something Different Triumph 20
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
dklawson Oil Leak - I Screwed Something Up. Triumph 8
D Finally got something done... Spridgets 8
60TR3A Learned Something New Austin Healey 16
Nunyas Not something you see everyday... Other Cars 10
M_and_P Thinking of doing something funky with the Mini British Motor Corp 6
kurts100 Am I missing something? Triumph 8
Anthony_S Something to look at Triumph 4
TR6BobNF Lotus - Forgot Something Spotted 4
B Who knows something about this? British Motor Corp 5
6 HELP! something broke in the rear end... Triumph 71
JPSmit Learned something new today Spridgets 3
Trevor Jessie I posted something in the classifieds! Spridgets 0
tri_carb_healey i did something stupid Austin Healey 13
Sherlock Something a little, ahem, different... Other Cars 3
drooartz I fixed something! MG 17
M TR6 This is something I should know,but don't TR6 Triumph 5
Hap Waldrop Something I need to say Spridgets 32
S And now for something COMPLETELY different...... Other Cars 7
jlaird Doing a bit of something. Spridgets 26
jlaird Miss Agatha was trying to tell me something Spridgets 4
S Something you don't see everyday..... Other Cars 19
