TR2/3/3A Replace wiring harness in steering column
R
Redoakboo
On the drive side there would be 3 green and white wires 2 from the main harness and 1 from the sub- harness of the blinkers. Only one green and white on the passenger because it is the green and white wirer extension from driver side that came around. The blinkers need to get to the passenger side and that is why there are 2 green and white on the driver side. Look in the trunk and see what color you have for each side that should give an understanding how the front and back wires work together for the lights in one harness
I checked both Green/White wires on the drivers side. I got reading at the front and rear directional lights for both. I connected them to a 4 way connector with the green/white wire coming out of the steering column. No blink? Another problem, as if I did not have enough. The left blinker works front and rear. When I turn on the parking lights, no blinking on the working side?? Dick
Jim_Stevens
I had a problem with accidentally swapping the parking light and the turning light leads, at the socket. I think I had to swap them at the socket, but that was my problem. May be yours?
sp53
That is correct the 3 green and white go together, so do the 3 red and green go together. There is a brown and green wirer coming out of the sub-turn harness and a green and brown in the main harness where are they hooked up? The green and brown and green and red wires can be confusing because the colors are close---- Like Jim suggested the front bulbs have 2 connections one turn one running light. The turn side of the bulb should be the brighter bulb.
Do you both parking lights working when you turn on the parking lights? Get those working first.
steve
R
Redoakboo
steve
Yes Steve, they both work but, per your earlier suggestion, I think I have the wires crossed because they are both very bright on the park setting.
R
Redoakboo
Steve, you are right as I had the wires wrong on all 4 lights. Now the parking lites are the dimmer and the left blinker works with the parking lites on. Now all I have to do is find out why the right blinker doesn't work? I get a reading on all three Green/White wires at the 4 way connector. If you will send me your email address .I will take some pic's of my wires. I have tried many times to post on the Forum, worked one time. I usually get the to large to picture???
sp53
The passenger side is where there are 2 extra wires you will not need ---look close at the colors. The green wirer with red stripe you need to hook up. The 2 brown and green are extra wires do not hook up. The brown is a reddish brown so it looks red, so sort those out first. teve53@gmail.comis my email.
Look at the picture I posted by itself with the fuel line in the picture that is the passenger side on this tread of page 1. It is an easier side to do; you got this coming together
steve
R
Redoakboo
steve
Steve, I found the extra Green with the red stripe on the psgr side. That is the only orphan wire left. The brown/Gn brown/blk went to the horns, they work. Where do I hook this orphan wire to? Dick
Jim_Stevens
It is left alone. Put a rubber bullet connector on it to insulate it from ground.
also, apologize for an earlier entry.. GR is Green with Red tracer, not Green. You figured it out,though!
R
Redoakboo
I have the Gn/Red two wires hooked up with the Gn/Red from the steering column; just like I did with the Gn/Wht ones. No right blinker? I have two Gn/Red spares left over, one on each side. I have tried both of these with the Gn/Red combo for the Rt side, still no Blink!!!
Dick
Jim_Stevens
on my column coming from the trafficator the GR and the GN look very similar, so it took me a couple of tries to get it right!
R
Redoakboo
The harness from my hub is new. I noticed that the hub wire, I thought was Gn/Bn I attached to the flasher.Maybe I have those two hub wires switched? Will try to swap and see if the Rt blinkers come on? Dick
R
Redoakboo
The G/N is the wire that runs to the flasher that I hooked up to the G/N from the hub. I tried to swap those two wires, then I lost the left blinker, that was working? The GR wire from the hub works the left blinker. I hooked it up to the two GR wires to get the left to work. I have two spare GW wires I hooked up to the hub GW wire, no blinkey? Dick
sp53
Sounds like you are on the driver side working. Hook the green and white wires together with the green and white from the trafficker making 3 green and white wires together. Now hook the blinker wirer for the driver side into those 3 green and white wires. There should be 4 wires total, 3 green and white and wires together and one from the front light blinker driver side.
steve
R
Redoakboo
steve
O.K. Steve,
I currently have the two G/W wires, drivers side, hooked into a 4 way connector along with the G/W wire from the hub. Now I have to find that elusive front light blinker wire? Is it G/W too? Where is it coming from?Am I missing a G/W wire? The G/R wires are all hooked up and run the psgr side blinker fine. Dick
sp53
The front blinker comes from the front end of the apron; it is the bright light of the front light bulb on the car. No they are not green and white. It depends on how the blubs have been coded; it could be any color. It could even be a tan color wirer with a stripe of color from the factory. Have you grounded both light bulb housings?
steve
R
Redoakboo
steve
I swapped the leads going to the parking lites as I had the blinker on the dim lead. The parking lights are now the dim ones and the left blinker, that works, is the bright filament. The two leads that go to the right parking light are red, and Gn/W. Each parking harness has a ground wire that plugs in the frame. The GN/W wire continues to the driver side . I have it in a 4 way connector which includes the Gn/W hub wire and another Gn/W wire that was also on the drivers side. When you say Bright light of the front light bulb on the car, you are referring to the parking lites?
sp53
Did you take the front apron light fixture housings out of the apron and look at the bulb sockets? There should be 3 wires coming out of each front socket 2 for bulbs and one for ground? And those sockets have a small piece inside the fixture to separate the 2 bulbs from each other.
The solid red wirer is usually the running light from the light switch on the dash that goes into the front head light system. That way when you twist the head light switch you get the running lights on with the head lights. Or when you pull the head light switch half way you get running lights only.
plus if you click on the pictures i posted that with enlarge the photo
steve
B Should I replace my old wiring harness? Restoration & Tools 8
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
V MGB Replace late intake manifold angled breather with early model straight? MG 1
W replace rigid master cylinder lines with flex. Spridgets 2
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
B A plan to replace BE floor pans Spridgets 0
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
J TR2/3/3A replace brake and fuel lines? Triumph 4
J TR2/3/3A Replace rusty sills? Triumph 10
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
JPSmit replace shocks in pairs? Spridgets 7
JPSmit When do you replace things? Restoration & Tools 22
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
AUSMHLY When to replace spark plugs Austin Healey 1
drooartz MGB What to replace when engine is out MG 10
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
TRMark TR4/4A Replace Water Curtain Triumph 5
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
S Replace original suspension for shocks? Austin Healey 2
J Replace the outside skin on a cargo trailer??? Restoration & Tools 0
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
7 How to replace door windows on a 77 MG Midget Spridgets 6
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
S Replace seal and dust cap BJ8 steering box. Austin Healey 23
gbtr6 TR6 TR 6 Head Studs, replace? Triumph 3
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
B Radiator - repair or replace? Pics attached Austin Healey 20
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
mailbox General Tech Fix, replace or rewire? Triumph 8
Kleykamp TR2/3/3A '61 TR3 Horns repair vs replace Triumph 15
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
britlover proper tire size to replace 5.90-15? Austin Healey 16
Rob Glasgow Replace clutch disk? Austin Healey 8
S TR4/4A Replace or rebuild heater control valve? Triumph 5
1 MGB Time to replace my top,,experienced recommendations welcome MG 10
R TR6 steering column removal bushing replace Triumph 2
