Recommended Spark plug gap
vping
Bronze
I'm going to run NGK BPR6RGP #7084 in the '74B. Pertronix LU-142A. Napa guy says to gap at .025" (which I used in the GT) What should I use and does it matter with Pertronix?
Agreed. The 0.028" wouild serve for a 'conventional' iggy system, the whizz-bang electronic stuff you've got will jump 0.032" with pleasure.
I triple the motion! I would run 0.032" with one-o-dem electrogizmo iggies... I run a Crane XR700 and NGK plgus set to 0.032".
So is my .025" in the GT too close?
Pertronix is an electronic iggie, if i'm not mistaken. I'd bump that up to the 0.028 - 0.030
Is it rigged with a Crane or other "embellished" iggy? If it's points, 0.028" is right. If it's an Opus or Pertronics or Crane, etc. it should be the wider gap.
GT is bone stock. The roady is the one i'm going to start souping (sp) up.
Points dizzy would have a 0.028" gap for plugs then.
Running .025" in the GT would make it run how then or should I say running a wider gap would do what & running a smaller gap would do what in either case? Sorry for the rookie question.
.025 is fine for a stock '67. Early cars ran a smaller gap than later ones. With modern ignition components you can easily run .028. With a sport coil you can push it even further, although the performance difference between the various gaps will not be large.
So what kind of coil should I have running the Pertronix? I have a few here but I believe they are all stock. The one currently in the car "looks" weird and I think I should replace it. GT has a lucas gold sport coil in it.
You might remember this. Note the broken porecelain thingy in the corner. This is in the roady.
What's up with the tupperware toothbrush holder? LOL! Ok, take that thing out and put something better in there. Pertronix sells a coil to match their EI modules, or you can use a Lucas Sport. I'd go ahead and change it to ensure the EI unit is getting the proper voltage. Points don't care but electronics can be damaged by too little juice.
I think I might order it. It's a flame thrower Moss #143-265.
I'm running 0.032" with Pertronix. Works well in race car with rice carb. No fouling ever.
I'm running the old style 25D distributor with old-style side-exit cap (made for solid core wires). And, or course, solid core wires.
I'm using an American GM style coil ($15) and external ballast resistor.
Your coil looks like the "ho-po" coils they sell in Summit Racing catalog. Intended as a boost for normal American cars.
I'll be running this; the 25D, NGK Platinum plugs .032", Silicone wires, Top exit cap, and a Lucas sport coil.
Ballast. I'm guessing that is the ceramic piece in my pic that is mounted to the fender? I don't need a seperate ballasted resistor correct? I can take all that off and mount the Lucas coil in typical fashion?
Somebody recommended them and not knowing any different, I got them. Should I not run platinum?
Just a waste of money, in my opinion. All I run in my entire fleet, are standard NGK's, BP6ES for the most part.
Even in the Volvo's.
Volvo warns against using plats in the older engines.
Jeff
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
vintagemechanic Recommended clutch kits Jaguar 3
J TR6 Tire Recommended for TR6 Triumph 3
Csarneson Seat Foams and recommended interiors? Austin Healey 13
T TR2/3/3A What air pressure is recommended in my Hoosier tires? Triumph 1
C Recommended reproduction wheels? Austin Healey 29
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
W TR6 Dashboard Recommended finish Triumph 5
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
C TR4/4A Recommended Books Triumph 8
R BJ8 with Servo, Is the 7/8 Master Cylinder recommended ?? Austin Healey 7
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
60TR3A What's The Recommended Stainless Steel Exhaust for '63 BJ7? Austin Healey 5
RickB Recommended seller of Spridgety bits Spridgets 4
I Recommended lubricant/fluid questions for 948 Spridgets 8
PatGalvin Engine Improvements Recommended? Triumph 6
T MGA Recommended order for building MGA front susp MG 1
T Recommended fuel pressure Spridgets 32
CinneaghTR Recommended Paint Shop near Baltimore, MD? Triumph 8
CinneaghTR Recommended Paint Shop near Baltimore, MD? Restoration & Tools 0
angelfj1 Recommended Lubricant for Lucas Windscreen Wiper Restoration & Tools 4
jjbunn Driving on two wheels - not recommended. Triumph 51
T manufacture's recommended fluids Jaguar 1
2wrench Hylomar recommended, but hard to find. Triumph 14
B Recommended Rover Reading Rover / Land Rover 1
B Recommended Reading MG 5
Ed_K Recommended break in for rebuilt engine ? Austin Healey 7
R Recommended Tire Size? Austin Healey 5
K TR2/3/3A Stripped threads in spark plug hole Triumph 28
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
CARSINC Spark plug thread size Spridgets 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
Carlbanan56 MGB No spark and engine cranking slow MG 10
kodpkd Spark Plugs Austin Healey 3
P TR2/3/3A NO spark at points Triumph 36
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
B Healey Won't Start - No Spark Austin Healey 38
L TR4/4A spark plugs Triumph 9
BierRunner TR6 Life without Spark :( Triumph 25
J TR2/3/3A No spark in TR3 Triumph 20
G TR4/4A TR4 Lacks Spark! Triumph 22
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
tr6web TR6 No spark 1972 TR6 Triumph 35
PAUL161 T-Series Odd spark plug encounter! MG 10
MadRiver No Spark Austin Healey 18
