MGA rear tube shock replacement for MGA
bobmga62
Hi Gang..
I wish to replace my rear lever shocks with a tube shock replacement.. (did it many, many years ago)..
I see MGB units listed for sale, but none for the MGA...I have interchanged the front lever shocks with MGB's, and I really can't see the difference in the back..
Before I invest $$$..will they simply bolt on and line up??
Thank you
r
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
P BUGEYE REAR TUBE SHOCK CONVERSION Spridgets 0
bigbadbluetr6 TR6 TR-6 rear tube shock conversion question Triumph 20
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
S Rear Tube Shock Converstions Triumph 17
Shinsen774 Replacement Tube Shock Rear-Advice MG 1
macino62 TR4/4A TR4 rear tube shock conversion Triumph 5
RobSelina DIY rear tube shock ideas [finished w/ pics] Spridgets 18
Andy Blackley Rear Tube Shock Conversions Triumph 26
A TR6 TR6 Rear Tube Shock Conversions Triumph 13
V TR6 TR6 Tube Shock Size [front and rear] Triumph 9
M Tube shock conversion[rear]. MG 5
B TR2/3/3A 1958 TR3 rear tube shock conversion? Triumph 7
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
busybrit Removing the drain tube fron the rear mains cap. Austin Healey 4
F Problem fitting rear drain tube to inlet manifold on BT7 Austin Healey 4
K TR2/3/3A TR3 Rear Overider Bracket "distance tube"? Triumph 10
KVH Replacing Rear Lever Shocks with Tube Shocks Triumph 24
R MGB MGB Tube Type rear differential MG 0
vping Welding to a rear axel tube. Can you? MG 17
AUSMHLY After market rear tube shocks Austin Healey 28
davester MGB MGB rear tube shocks...which ones? MG 18
mgbmedic MGB rear tube shocks for MGB MG 20
R TR6 TR6 rear ride height with tube shocks Triumph 5
T tr4-rear tube shocks Racing 2
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
