Radiator Air Flow
John Turney
John Turney
I bring this up because if I were to address your issue, I would favor installing a similar low mounted scoop under a few inches behind the bottom of the shroud with 2 upward facing fans. This would allow uninhibited air flow through the grill to allow cooling at speed (as apposed to many who have found the constant running of an electric pusher fan mounted on the cross braces that block grill air flow at speed).
Just my thoughts,
Ray(64BJ8P1)
Thanks for the input, I've given that some thought. What my initial test makes me think though, is that when fans are not against the radiator the air would take the path of least resistance and be deflected by the radiator and perhaps out the grill if not moving.
I have spent a bit of time thinking how an engine fan shroud could be constructed and installed in the tight Healey space without having to have someone fabricate one at great expense. As I noted in an earlier post, I have a Texas Cooler fan, it is offset to the left side of the radiator and there isn't much room. The attached drawings are based on my car (BN4 body, 3000 engine, stock radiator and NTAHC fan). I use simple aluminum shapes readily available at the local hardware store and no complex forming. One shows the shroud with the radiator and one without. Hopefully these show up. Comments are welcome:
John,
Why is your fan offset to the left? I don't have my BJ8 here, but it's always appeared to be directly behind the radiator.
Many moons ago, I bought a 'kit' from BCS that included a 7-bladed flex fan and a shroud that doesn't enclose as well as this appears to. The flex fan was one of the most effective temperature control additions I've done, but it was too noisy at idle--where it worked best--and I replaced it with a Texas Cooler. The shroud bolts to the lower radiator mounts, and as far a i can tell it's symmetrical.
steveg
John - thanks for uploading the pdfs - they work for me.
Wonderful work!
One minor comment - what about pop-riveting the side assemblies together?
Not quite clear from the drawings - does the rear piece fold over for the two top pieces on either side of the curved fan guard?
John Turney
John Turney
I suppose the side assemblies could be pop-riveted if one has the proper tools and rivets.
Yes, the rear piece does fold over the for the two top pieces on either side of the curved fan guard.
ScottM
The best solution we have found up here in the high desert. Is to install pusher electric fan in front of radiator, and add a 15 inch stainless steel 5 blade fan. /And space it as close as you dare to radiator! Works well, and maintains oem looks.
John Turney
John Turney
My Texas Kooler fan has worked fine up to 105F. Beyond that the people overheat. I just noticed that although the fan blows a lot of air, very little of that air comes through the radiator at idle.
RAC68
Hi John,
Your observation of low through-radiator air flow at idle is telling and I would expect you are either drawing air from openings under the shroud or loosing fan draw at the end of the blades.
Does your shroud incorporate panels blocking off radiator areas outside the circumference of the fan opening? I bring this up because of your comment about observing little or no radiator flow-through at engine idle. Forcing all air to flow through the area covered by the fan would give greater air flow and, even with some radiator air recirculation, would result in greater fan pull. As I understand, good fan draw also requires the fan have a tight fit with the surrounding shroud and a loos fit will allow functional efficiency and loose draw.
However, although the addition of panels, as you describe, that focuses all air flow through the fan-surrounding shroud would make the modification purposely effective at all speeds (including idle). Even if the original modification would present an obvious appearance quite counter to the original, I believe once solved, its presentation could be modified to be consistent with traditional Healey themes of presentation
Ray(64BJ8P1)
John Turney
John Turney
Hi John,
Does your shroud incorporate panels blocking off radiator areas outside the circumference of the fan opening? I bring this up because of your comment about observing little or no radiator flow-through at engine idle. Forcing all air to flow through the area covered by the revolving fan would give greater air flow and even with some radiator air recircl
No, it only stops air from the sides being drawn through the fan. If I block off radiator areas outside the circumference of the fan opening, then I wouldn't get increased flow when moving.
RAC68
John,
You may be right but here is an example of an enclosing radiator fan shroud that seems to provide substantially better flow over the full radiator. The difficulty I see is the area needed to allow full under-shroud flow across the radiator core. Additionally, it definitely looks non-standard.
Dale Spooner's 1977 MGB with Ford V8.
According to Dale, "Fan shroud improves idle and low speed cooling".
Just my thoughts,
Ray(64BJ8P1)
Patrick67BJ8
John,
Just my thoughts,
Ray(64BJ8P1)
I’ve been told that it’s important for the fan blade to stick out from the shroud like this, half way out or there’s problems with turbulence which decreases the cooling performance.
John Turney
John Turney
John,
Just my thoughts,
Ray(64BJ8P1)
Ray,
I may have misunderstood what you said. I thought you meant blocking off the radiator in front of the fan. Yes, my design blocks off air flow so that all air coming through the radiator above the upper cross member goes through the fan opening.
John Turney
John Turney
I've seen that the fan blades need to stick out either half way or 2/3 of the way depending on the shroud manufacturer.
HealeyRick
Not sure if any of this is transferable to a stock Healey as the measurements of engine placement will be different than with a stock motor.
First off. I'm using a 14" Maradyne fan installed as a puller: https://www.thewedgeshopstore.com/products/Maradyne-14in-Electric-Fan.html
The first iteration was the fan installed on an uprated stock Healey radiator with a shroud made from cookie baking sheets:
It provided some benefits but not as much as I wished, so my present set up is a Wizard aluminum radiator with an integral shroud:
This was a custom build in order to position the back of the fan motor clear of the V8 pulleys and also involved removing the cross brace and mounting the radiator as close to the hood locking mechanism as it could go. Clearance is still tight after all the modifications, but it does fit and cools the motor sufficiently,
I'm still hoping to drop underhood temperatures a bit with my hood louvering (but have to admit this is more an appearance than mechanical necessity)
I was very happy with the work done by Wizard. They were willing to work with me to design a radiator that would fit in the limited confines of the Healey and the fab work on the radiator is very nice. I don't think an aluminum radiator is a one-stop cure-all to Healey overheating but has to be combined with all the methods that have been discussed to maximize airflow through the radiator.
turtle
Here's my custom Wizard setup. My mechanic just finished the installation today. He was very impressed with the build quality and it dropped right in.
It's Wizard's 100/4 radiator, upgraded to 1.25" tube, Spal 14" brushless 500w puller fan with shroud, modified for Chevy V8 (swap in/out locations).
Only snag was the lower hose not wanting to fit with the new shroud but a little customizing was expected. I have high hopes that I won't need to replace the bonnet with a louvered one... since the solid bonnet 100s are so "rare" now and I want to keep the "stock" look... well except for the giant side pipes that always give me away.
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
R Air Intake Deflector - Radiator Austin Healey 8
K Radiator air deflector Austin Healey 6
af3683 TR2/3/3A Radiator Air Deflector / Shroud Triumph 31
I TR6 radiator air deflector recommendations Triumph 10
Monark192 Radiator lower air duct panel for 74.5 B MG 3
AUSMHLY radiator air shield wire placement Austin Healey 11
S Radiator Air Deflectors Austin Healey 3
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
FlyingCat Spitfire Radiator and fan Triumph 5
aero3113 Radiator overflow catch tank Austin Healey 15
