wifegonnakillme
First to follow up on a previous post re rad pusher fan hook up. I had asked how folks attached their rad fans thinking I had to go through some elaborate process of welding on braces or bolting it to the body some how - In fact, when I got the fan (Hayden), it came with what look like long plastic thumb-tacks you simply push through the fan and then slide thought the rad between the fins - simply attach another do-hicky at the back and the fan is mounted.
I slipped the 12" fan in through the front grill and had it mounted and wired to an under dash switch in well under an hour - would have been shorter if my wife hadn't been pestering about doing the gardening...
Anyway, such an easy job to do I would highly recommend for the peace of mind...
Now - the question I have is how does one orient thouse TR3 rad ducts in front of the radiator? I have a 3A and after spending some time with it, I can't figure out which side is up on the two cardboard Moss rad ducts... I know mine had them at one point since I can see three screws in the deck of the apron in front of the rad... anyone do this? Easiest way to describe is probably to tell me where the long straight side goes - I think down, but I would have had to bend the crap out of it to get it to go...
Cheers and thanks -
Kerry
Cheers and thanks -
Kerry
