Question on Cam Timing.
PAUL161
What cam degree should be set for best performance on a street version 1800 engine using a stock cam? What effect will it have on idling?
billspohn
Just set it using factory timing marks (unless you have a set of Indian made gears with the timing marks made 'free hand'.....)
PAUL161
PAUL161
Bill, I apologize for not making the question more clear. What I should have said was, I am building a new engine and installing a double row chain setup and the cam gear can be dialed in. How far can I advance the cam for better performance without going to far? The engine will be bench tested, but I would hate to have to pull it down to re do it again.
PS, I forgot to mention that it is a 72 1800.
Dave Russell
Yoda - R.I.P
Advancing the cam timing up to 5 degrees, crankshaft, would result in more low rpm torque.-- At the cost of less higher rpm torque & horsepower. There is no way to get both by changing cam timing. If in doubt, go for the stock timing.
PAUL161
PAUL161
Thanks Hap!
D Cam Timing question. Spridgets 11
N Cam question????? Spridgets 11
krswen Question about XJ6 cam covers Jaguar 6
R degreeing cam spec question and procedure Spridgets 23
M Cam bearing question and FO8 question Triumph 10
frankenstang57 Spitfire Spitfire 1500 fast road cam question Triumph 4
K TR2/3/3A Idle Question...TR3 with Cam Triumph 7
curtis Twin Cam engine question Lotus 41
Morris Cam Question Triumph 14
Morris Nother Cam Question Spridgets 3
David_K BJ8 cam question -- Regrind and Where? Austin Healey 7
Basil New Cam question Triumph 11
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
