After 35+ years of racing and designing my own cams for 10+ years, I'm of the opinion for most applications; knowing the lift, the duration and the lobe centers is all that is necessary. With that information and remembering our high school mathematics, one can figure out everything else with a degree wheel, dial indicator and a dead stop. Find TDC using the dead stop and degree wheel. Then used the degree wheel and dial indicator to find out all the information you want. Most every cam ever ground for the A-series engine will work in the +/- 4 degree range of setting the cam in "straight-up". Straight up is when the center line of the intake is the same as the exhaust. This is pretty much the same for Triumph and B engines as well. 99.9% of the time, the cam is advanced to boost low end performance and compression is used to complete the top end.
For street applications, the lobe centers are usually wider than the race application. My guess is that a stock MG1500 cam is going to be in the 108 to 112 range. Probably around 110. Advanced would be 106 degrees. Anytime you play with cams in a racing application (high lift and advanced), need to double check the valve to piston clearance as well. Around +/- 10 TDC, the valves get pretty close to the piston.
As Hap said, having the cam specifications and the tools are one thing, being able to make adjustments is another. With the A & B BMC engines you have keys and Verniers. With the Triumph, only the Vernier makes the needed adjustment available. It is a rare cam that is ground exactly matching the attachment timing. Mixing gears from numerous engines might find you 1-3 degrees.
Also, most cam merchants won't tell you everything you want to know. They will usually tell you lift, advertized duration, lobe centers and running clearances. Some won't tell you anymore than where to set the cam into the engine and clearance. Keeps some of the "Magic" in the designs of their bumpsticks.
Mike Miller
Comptune
864-638-6316
