Progress on the $40 Paint Job
martx-5
Awhile back, I ran into some stuff on the internet about a $40 paint job. The original guy that started this was using Rust-O-Leum. A guy from Australia tried it, and decided that the paint he got (it wasn't Rust-O-Leum) had problems with fading. He redid the car (Miata) with Brightside, which is a Marine paint made for topside use. Very UV resistant. I got intrigued, and decided to go with this stuff. Look a page two of the link to see his results.
After messing with this stuff for the last week, I decided that using a foam roller was NOT the way to go. It left too many bubbles in the paint that mimicked ORANGE PEEL...just what I was trying to stay away from. I wound up using a foam BRUSH. With the Brightside paint and their brushing thinner, this stuff lays flat as glass.
I'm about 3/4 of the way done with the car, and I like the results. It's alot of work, but it's starting to pay off. Of course, this $40 paint job has esculated to about $150, what with the cost of the paint all of the sandpaper, polishing compounds etc.
The pics below are shown with just a quick polish after a 2000 grit sanding. I'm going to wait about a month for the paint to harden up before I get serious.
EDIT: How come two of the pics wound up in the trhread and the other three have a link attched to them?? Is it because those two were cropped??
Brosky
Those look fantastic !!!
If I didn't know you better, I would sear that you were joking about this. I hope that you're taking step by step photos for the new wiki knowledge base.
Definitely keep more progress info coming as you move forward.
Brosky
John just asked me about that? What do you mean? I uploaded a new one that should look like this:
That's what shows in my profile???
Brosky
I forgot to ask, how many coats did you apply? What about drying time in between coats?
Also does my avatar look like the attachment in the previous post? On my computer it does.
Thanks,
martx-5
martx-5
I'm putting three coats on all the panels. The drying time between coats is a real killer...about 16 hours. That means I've got to find room in the basement to lay the panels out while they dry so I can work on another one. This kind of work is great if you're working a little each evening. Paint up a couple of panels, and then the next night sand and put on another coat. Clean-up is easy...chuck the brush and put the top back on the can of paint. The smell is nowhere near what you get when spraying. It's just a faint aroma when I go downstairs to check things out. Another advantage is that there is NO wasted paint like you get when spraying. I should be able to wrap this up with two quarts of paint...three coats on everything except the interior panels which will only see two coats.
T
TRDejaVu
Art,
Looking good. As you know, I'm using the Rustoleum Pro and I got the orange peel effect at the beginning, which I was wet-sanding out OK . I went back to the Mopar thread and saw that one guy follows up the roller with a clean foam brush drawn very lightly over the surface. I tried it and it works great; very smooth, no orange peel.
Of the parts that unbolt and go to the basement, I am now on the 4th fender and drivers door; passenger door, trunk lid and hood to go. Now the weather has warmed up I am back in the garage and prepped the rear end this weekend; I will be painting it this week. Should go quicker (work permitting), now that I can do things in 2 areas at a time.
DNK
Paul- On my computer it looks like this
martx-5
martx-5
Brosky said:
Art,
Are you sanding between coats as well?
Yes, I wet sand between coats with 1000 grit. There are always some small runs that occur. I think it's because of the brush flowing thinner that I'm using. It allows the paint to flatten like glass, but it also allows some running wherever the panel heads downward while drying. If I'm careful with the application, I can keep the running pretty much in check. Each coat goes on better then the last one. By the third coat, runs are pretty much non-existant and I can then hit it with the 2000 grit and polish.
John_Mc
Paul, that looks a LOT like my wife in that TR6 with you!!! I can't say I blame her though. You really ARE a handsome devil!
Brosky
John,
I'm seeing my avatar (distorted) in your posts and seeing mine (correctly) in my posts., but you and the others are seeing your avatar in mine.
I'll forward this thread to Basil and see what he can do with it.
Sorry and thanks for telling me,
Administrator
Boss
I am seeing a yellow TR6 (same image) in both your avatars? So who actually owns that Yellow TR? The other person should try uploading your avatar again.
Brosky
Thanks Basil. I'll PM John as he is off line at this time.
Brosky
I said I was sorry and that time I actually meant it!!
Just for that, next time I won't mean it!
TR674
Art
well done. 10 points for courage. As Paul suggests, can you document it in detail?
Regards
Craig
Joe_Pinehill
WOW that does look to good to be true, can you try document your progress on a website? What kind of car do you have?
Bayless New Prefect progress Other British Cars 7
Bayless More Prefect Progress Other British Cars 2
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
mctriumph 61 Morgan making progress Other British Cars 3
SNClocks Progress Update Spridgets 5
SNClocks Progress Shots! Spridgets 15
prb51 AH Search in Progress Austin Healey 35
C My 2500M progress/questions thread TVR 5
D GT6 9 months later. GT6+ progress Triumph 3
J Restoration Progress - Boot Installed Austin Healey 1
F GT6 Looking to sell - in progress restoration Triumph 19
Cutrog1 How do I respond to all responses and add progress report on original article? FORUM Navigation Questions 3
Bayless More Sprite progress finally Spridgets 23
Bayless Sprite progress faster than expected. Spridgets 3
doc50 1958 Metropolitan Progress Other British Cars 4
Bayless Even more progress - the Prefect Other British Cars 5
Bayless Progress finally begins Spridgets 5
D Progress.... Spridgets 4
Rut TR4/4A Shop progress Triumph 21
Rut Shop progress Spridgets 25
Rut MGB Shop progress MG 4
69MGC MGC Wheel well restoration progress MG 4
69MGC MGC My MGC Restoration Progress MG 4
simon1966 100 Restoration Progress Austin Healey 13
Jim_Gruber Bugsy IV Progress today Spridgets 34
drooartz Making [tiny] progress Spridgets 14
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Marvin Gruber TR5/TR250 TR250 progress Triumph 15
Jim_Gruber Actually made some progress on Bugsy II Today Spridgets 4
drooartz MGB-GT Other small progress MG 3
D Bugeye Wiring Progress. Spridgets 3
Brinkerhoff T-Series TC restoration progress MG 16
RickB Knox Custom Chrome - my grille progress Spridgets 58
sim In progress 58 paint job by Premire body and paint in Visalia Ca Restoration & Tools 0
jaegzie Long time since I've been here but progress has started. Bigeye rebuild Spridgets 9
Marvin Gruber TR2/3/3A 1956 TR3 in progress Triumph 28
oxford Progress Video Austin Healey 6
2 MGA mga mk II in progress MG 2
7 Post-War Other Back to making progress Triumph 5
N Spitfire 75 Spitfire progress Triumph 6
oxford BN4 progress Austin Healey 8
drooartz MGB Finally some progress -- floors painted MG 4
drooartz MGB Making some progress with the doors MG 5
Darwin Spitfire Joy in Mudville [Spit6 progress] Triumph 1
J TR2/3/3A Need to sell my '56 TR3 restoration in progress Triumph 21
Lin Progress Up-date from Rich Berman and Andrea Austin Healey 10
Pythias 1275 transplant progress. Spridgets 50
64rocksprite Re-assembly progress and a wiper rack question Spridgets 8
M TR2/3/3A TR3 progress pictures Triumph 26
mcguijo Some progress at last Triumph 2
