TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4
Gerald_Gordon
The mechanic who has my car in a distant state tells me to replace the front springs and suspension bushings in my 1961 TR4 that is used only for daily driving, not for rallying or autocrossing. I suppose that one of the Delrin kits would be superior to the stock rubber, but I am concerned about squeaking. May I have your recommendations, please?
PatGalvin
Hi Gerald. I have no opinion on the front springs - maybe others can weigh in. Was the car sagging in the front? I used urethane bushings instead of rubber for my TR3A front end rebuild (similar to TR4) and I really like the urethane solid feel. I have no issues with squeaking yet. I would not hesitate to use urethane again on my next resto project! I think Delrin is a hard material used only for certain applications (like upgrades to steering).
Pat
JerryVV
To me the issue is the quality of replacement rubber bushings. Having spent many years in the rubber industry associated with noise and vibration solutions I am suspect of the rubber compounds in the aftermarket bushing. They may be excellent but they may not, at least the OEM bushings had some engineering associated with their development. I'd go with the urethane, personally on my TR4A I use Delrin and I like the feel. As for springs, be careful, again are the replacements the same spring rate? I'd be asking him to measure the free length and if they are in spec keep them.
malbaby
Re the front coil springs.....There are a lot of different springs on the market, namely spring rate, length, wire diameter and the number of active coils. I would not replace the springs until you were sure of your preferred ride height and comfort.
[I am currently having a pair custom made].
H Preferred Motor Oil for 948cc engine? Spridgets 6
KVH General TR Best Year for TR6; Preferred over TR250? Triumph 11
CinneaghTR Preferred Jack and Jackstands for LBCs? Restoration & Tools 11
S Preferred Side Mirrors Austin Healey 35
M Preferred valve cover gasket Triumph 12
healeyboz preferred clutch brand Spridgets 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
X Front End Alignment Austin Healey 14
