good luck fitting the transmission back, read my post on installing the transmission back in the car. Definetly a two man job.
Sorry Johnny, got to disagree with you there, not easy but doable, if you set up a plank of wood under the engine/gear box on jacks - I used screw jacks, when you remove the gearbox, you can use the same set up to replace it. Passenger seat come out, anything from the engine connecting to the bulk head comes off - my BJ7 has a rod from the carbs, all gear box rubber mounts come off, starter motor off, prop shaft off, disconnect feed to clutch slave cylinder and/or remove it. and tilt engine and gear box with the screw jacks so that the rear of the gearbox will clear all obstructions and remove all bolts engine/gearbox.
Gear box will slide up the plank with a good pull and possibly a twist to clear the bell housing / bulkhead and it can be removed through the passenger side. Re-installing is same in reverse, but you will need to rotate the prop shaft connection at the back of the box to engage the first motion shaft into the clutch and the end of the crank shaft as you slide the gear box home. I do understand that different models present slightly different challenges regarding bell house / bulkhead clearance but on the BJ7 at least, it does not present much of a problem.
Many hands WILL make light work of things and the BMC team mechanics could replace a worn clutch plate in an hour - or so it is said.
Bob
