TR2/3/3A Placing the differential on the frame
sp53
Placing the differential on the frame, I got the TR2 frame painted red, but it looks more orange in the pictures. I have not put the differential on the frame because I have not rebuilt it, yet and have actually never done much to a differential. The gears look good, so I will probably only replace the seals and axle bearings. Anyways I thought I would put the differential on the frame un-rebuilt and use the frame as a way to hold it in place while I replace the axle bearings and seals. Is that not such a good idea? I am I making things more difficult? Well any thoughts are appreciated.
Steve
Joel Lester
Personally I would rebuild the axle off the frame. You've got a nice new paint job and you might chip the paint. Once you get the axle all rebuild then mount it on the frame with the springs and shocks. It's WAY easier to put all that on while the body is off... trust me. I just had to re-do my springs and shocks with the body on and it wasn't nearly as fun when I was rebuilding the frame! LOL!
Joel
CJD
Your frame looks nice. The red is very striking. There is something to be said for holding the diff securely with the frame. The down side would be having to bend over to work on it.
mastaphixa
Bronze
I worked on mine while it was on a work bench. As CJD states working bent over is a bit taxing.
T Spitfire Need help placing date and point of origin Triumph 5
2wrench Synthetic oil used in placing pistons...opinions Triumph 6
S TR2/3/3A when rebuilding a differential Triumph 9
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Differential clicking Triumph 6
CARSINC For Sale Sprite Differential Spridgets Classified 0
S TR2/3/3A old 4 bolt axle differential. Triumph 11
T Rear/Differential "Clunk" Austin Healey 2
W TR2/3/3A Differential cover torque Triumph 4
G Spitfire Spitfire 1500 differential whining Triumph 6
B Midget Differential Capacity Spridgets 5
R Changing BJ7 Differential Ratio Austin Healey 10
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
A TR6 Installing differential and transmission Triumph 10
Sarastro TR4/4A Differential setup question Triumph 12
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
J TR6 Differential / Rear Axle Triumph 1
71TR6 TR2/3/3A Locker Differential- I have one but what is it? Triumph 9
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
Got_All_4 TR6 Differential side hub measurement Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
glemon General Tech Differential flange removal Triumph 11
DrEntropy Wanted Later ['67~'68] differential. MG Classifieds 0
J Flaking Paint Inside Differential Austin Healey 6
P TR2/3/3A Another Differential Question Triumph 22
P TR2/3/3A Differential question Triumph 6
DrEntropy MGB Differential with too much lash MG 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
L Wanted Tr6 differential Triumph Classifieds 9
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
N Spitfire Changing Differential oil Triumph 14
R TR2/3/3A Sluge in Differential Triumph 21
J TR2/3/3A Differential Side Gear Backlash Triumph 3
J TR2/3/3A Differential Rebuild - Gear Markings Triumph 18
D Clutch-Type Differential Austin Healey 5
K TR2/3/3A Correct oil level for differential? Triumph 5
W Differential oil for 100/4 1954 Austin Healey 14
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T Differential Pinion Bearings Austin Healey 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
