Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
I have 11.7 volts at ing switch wire, 10.5 across coil, but only 3.2 volts during cranking. No spark with timing light. all grounds are good. Correct connections to coil.
I would suspect either bad battery connections or high resistance somewhere. You might want to have the battery checked with a load tester. Most auto stores have them and will do the test for free.
I have had exactly the same problem with pertronix in the past. Nothing wrong with the car. The problem lies with the output circuit in the pertronix. Pertronix know about the problem and will change it if you insist. They may try and tell you its your fault (grounded wire during installation, etc) but its not... If you bought from Moss or elsewhere I'm sure they will change it..
Maybe I should have asked before I wrote my first response but what exactly is the problem?
1. Is the car starting?
2. If so is it running okay or is it misfiring?
3. What are you using to read the voltage and have you confirmed the readings with another VM?
4. When are you getting the readings--Before starting, during cranking or after ignition?
You mentioned a problem with the Pertronix circuitry. Do you have a statement of the problem and has it been resolved. I ask this because a friend is about to order a Pertronix for a negative ground 1967 BJ8 and I happened to mention your comments. What is your suggestion?
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
