Overdrive Problem
brdave
Tried to get the OD working on 1973 B today which will not engage. Drained the gearbox and OD, replaced the large filter, installed new solenoid and refilled 20-50 Castrol. Overdrive still does not engage. With the key on in 3&4th gear there is power at the connector and with key on etc.we can hear the solenoid click when switching the OD switch on. Does anybody in this forum with more experience and expertise with overdrives have any suggestions or advice to offer?
thanks,
dave B.
scott421
Member
Could be a pressure problem ? I dont know if you can drive the car with the box exposed ? On my TR6 the tunnel cover can be removed to do this . If possible drive and activate the solonoid , on the other side of the box from the solonoid is a lever , if you can , push the lever forward to see if that activates the o/d . This lever should be lined up with a small hole in the casing . This is conected by a rod through the box to the solonoid plunger . If the lever is not aligned correctly it will not engage the O/D. Try to get hold of a pressure guage to measure the pressure , on my A type a minimum of 380psi is required to activate . Check this and also the seat on the pump non return valve and accumulator valve . If a minute piece of dirt is there it can effect the presure too.
AlanT
With the internal solenoid , you should barely hear the click of the piston when the switch is turned on. From years at the dealer and beyond , the #1 problem with LH overdrives is a sticking oil pump. Following the manual carefully , you can unscrew the cover holding the check ball and see the bottom of the pump. Rotate the driveshaft and see if the pump piston moves. If not then push up on the piston. You will know if it was stuck by the sound it makes. If that is not the problem then check the non-return valves (balls). Note: Do not unscrew the cover that contains the pressure regulator valve.
Alan T
BOXoROCKS
Good questions, I am having a problem also on my 74. It works fine on cold days, but fades out after a few miles on warm days. I checked the oil, added some 80/90,(I am a TR guy also thats what the manual calls for)any way no change. I suppose I can give it a general cleaning,but I thought I would get some input first. It is obviously losing pressure, I think,..is it the cold oil that makes it work until it warms up and thins out? OR.. could it be that the selinoid is losing its charge.
Keoke
Seems like Scott gave you some good pointers Dave. I only want to add a small recommendation here. When you get the problem resolved, drain off the Castor 20-50 oil and refill the box with a single detergent free oil like Valvoline VR1 50 W oil.---Fwiw--Keoke
B
brdave
Scott, unfortunately it is an unassessable internal solenoid LH Type OD and cannot be tested as suggested.
Alan,
Is the cover holding the check ball the one with the two holes found under the large screen filter?
Secondly, Is the pressure regulator valve beneath the bolt type plug adjacent to the filter cover and solenoid cover?
Just as a note I have just had a consultation with a local british mechanic who is suggesting doing a pressure test which I believe would be using a pressure guage attached in place to that bolt type plug.
I am beginning to think that I should check whether the oil pump is sticking as Alan suggests first.
Regardless we have buttoned things up for now and will probably not be able to get back to it for a couple of weeks.
I will report my findings!
Thanks,
dave
Steve_S
A sticky pump will do it. Clogged oil passages are also a possibility. A pressure test is a good idea. Off the top of my head I think the LH should read around 400PSI but don't quote me on it.
T General TR Overdrive problem Triumph 4
T TR2/3/3A Problem with angle drive for overdrive Triumph 20
D TR2/3/3A TR3 Overdrive to transmission mating problem Triumph 8
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
S TR4/4A problem with overdrive Triumph 5
S Overdrive solenoid problem on a BJ8 Austin Healey 3
D Overdrive problem when raining - bj8 Austin Healey 23
bighealeysource Up-date on BN2 overdrive problem Austin Healey 9
Coyote1 J Type Overdrive engage problem Triumph 3
bighealeysource Overdrive problem Austin Healey 5
Tinkerman TR2/3/3A Overdrive Switch question. TR3A, Problem Solved! Triumph 10
R BJ-7 overdrive relay wiring problem Austin Healey 1
S Overdrive Problem; Won't Engage Austin Healey 24
N Overdrive Engage/Disengage question [Problem...] Austin Healey 18
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
