Took the car out yesterday for a little spin and noticed the overdrive not acting correctly. Driving down the road with the switch 'off' (40 mph) then set the OD switch to 'on' - the overdrive engages fine, drops rpm, etc. but only stays engaged for about 60 seconds then disengages. If you apply just a little throttle it disengages... Tried it at different speeds/rpms (3000,3500,4000)...
Thoughts?
/ubbthreads/images/graemlins/patriot.gif
Thoughts?
