Re: Overdrive issu
All good points, thanks. To answer some questions, OD does not exist under any circumstances. Driving down the road, tunnel off, 4th gear, 45 mph, OD switch on, solenoid clicks, lever drops down off its test position, No OD. I am confused, however. All three manuals I/m using (TR6, TR3, AH 3000) all state that energizing the solenoid will put the manual lever in the test ( holes lining up for 3/16 inch rod) position. This Healey works just the opposite. Holes are lined up with OD off, No power to the solenoid. My 57 TR3 is exactly the same. What am I missing here?
