Overdrive display light
G
Hey guys,
In the process of finally installing my J-type overdrive conversion in my 73 TR6, am a newbie in the use of this device and am about two weeks away from finally getting it on the road. (other things to do as well) Question: have any of you installed an overdrive-display-light on the dash? I thought it would be good to have a discrete indicator light that would light up when the overdrive is engaged, drilled anywhere into the dash. I remember years ago a friend had that on his big Healey and don't know if it was an option. In other words, the light would come on when the OD is being used, especially helpful at night. Or should I stick to fixing teeth....
Bill
MDCanaday
I like the idea but dont know if the LUCAS demons will take it well!!!! Perhaps a little lcd lamp would draw little enough current as to make no matter,since the smoke only escapes under loads.
MD(mad dog)
piman
Hello Dr. Bill,
Jaguars had an indicator on their MK 2 model.
Certainly it will be an easy job as you described, (ignore the Lucas jibes from the disrespectful, if Lucas was good enough for the DFV Cosworth F1 engine then!!) but, personally I rely on my ears to let me know if it's in or out.
Alec
Dave Russell
Yoda - R.I.P
Once you get familiar with the car, it should be very easy to tell if it is in OD or not. Just like it is easy to tell if it is in third or fourth gear without looking at the shifter. IMO, just another gadget to cause trouble.
V
vagt6
No, Dr. Bill, it's a great idea and I'd like to have such a light for my GT6 Jtype.
It should be easy enough to do by tapping the light's hot wire into the wiring harness (white wire, I think?), maybe at the OD on/off switch (mine has a column switch on the left side of the steering column, your's probably has the shift lever/gear knob switch).
I think I'll put my light in the handbrake warning dash light.
Here'a a link with a pretty good wiring diagram of a Jtype to give you an idea of where to start:
https://www.buckeyetriumphs.org/technical/JOD/JOD1/JOD1.htm
Let me know what you decide, it would be useful to everyone with an OD.
Bugeye58
Indicator light? We don' need no steenking indicator light!
Tach, Speedo, ear. What more do you need? If I put one on my GT6, I'd probably have to upgrade to an alternator!
Jeff
Paul Johnson
Light would be easy enough to install; for example, how about the oil pressure warning lamp, since you have a real pressure gauge and don't need that? But as many say here, you'll not really need the light, being in tune with the car. Biggest problem with the o/d is getting back into a regular car and constantly hitting the turn signal switch hoping to drop a few revs.
piman
Hello Dr. Bill,
if you follow the diagram on the link given, you will need to pick up the lamp supply from the solenoid or the switched side of the 3rd\4th gear inhibitor switch. Connecting anywhere else will not give a true indication. By the way my Triumph has a relay to switch power to the solenoid as it takes good bit of current initially to draw in the solenoid. The solenoid is actually double wound with an internal switch to switch off the heavy 'pull in' circuit. Might be worth considering fitting one.
Alec
[ 02-11-2004: Message edited by: piman ]</p>
Ralphanator
Back in the day when i owned a 71 TR6 with overdrive it did not have a light! It sounds like a good ideal but I didn't feel the need at the time!
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
R TR2/3/3A Overdrive wiring installation Triumph 14
BN6_2197 Overdrive engaging with time delay Austin Healey 39
P Broken Overdrive Switch in Gear Knob Austin Healey 14
T Overdrive Problems Austin Healey 18
T TR2/3/3A overdrive solenoid Triumph 3
T Spitfire Overdrive again and again... Triumph 5
