Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
My BN4 overdrive: I wish to by-pass the kick down switch and use only the IP-mounted switch. I did so many years ago on another and am having difficulty figuring the BN4 by-pass wiring. Any help appreciated. David
Hi David
Here the diagram of OD electric section https://picasaweb.google.com/lh/photo/9GPPXKXl48NwLHhO8C-HAtMTjNZETYmyPJy0liipFm0?feat=directlink
and the interior of the throttle switch https://picasaweb.google.com/lh/photo/Yd2td-wKTN7cYNRfs-Sg3dMTjNZETYmyPJy0liipFm0?feat=directlink
contained in a box mounted on the firewall.
NOTE
<span style="font-weight: bold">The throttle switch</span> ensures that, when the overdrive
toggle switch on the dash is flipped from
OVERDRIVE to NORMAL, the overdrive does
not disengage while the driver’s foot is off the
throttle. This is important, because when the car
is decelerating, the engine is providing what
is called “compression braking” and power
is being transmitted from the rear wheels forward
through the drive train, so if the overdrive
were to disengage, the consequent increase in
engine rpm would cause the drivetrain to jerk
and could cause harm to the engine.
I have heared that some racing AH eliminates this switch
This is a very simple work without strip the switch from
the car it is sufficient to connect a wire strip from the two contact screw -so the throttle switch is bypassed https://picasaweb.google.com/lh/photo/nxpBsYxEyqyUvwVg2Lok3tMTjNZETYmyPJy0liipFm0?feat=directlink
Cheers
Andrea
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
