Options & measurements for front floor repair
tdskip
Sorry guys, I'm just full of questions this AM. Can you tell I'm enthusiastic about getting her sorted?
Anyway, as you probably know from the other posts it is time to get drive side front floor repairs. The passenger side can be hammered back into shape I think, but the driver's side clearly needs to be cut out and replaced.
I haven't been able to find just the front section of the floor and really don't want to pop for the full floor since it isn't needed. <span style="text-decoration: underline">So unless any has any sourcing ideas on where to find just that front panel (maybe a scrapped car being cut up?)</span> I think I'm going to have to fabricate the panel myself. Not quite sure how I'll do this, but worth the effort in learning how...
Does anyone have the measurements of where the foot well / indentation is on the floor board? That is to say, how far in from the sides of the panel does the taper start and how deep is it?
Thanks!
apbos
Tom
I'll see my car in the am and get some measurements. Drivers side only or both?
Paul
T
tdskip
Thanks for the offer guys, but looking at Mike's pictures I've realized that there isn't any way I'm going to be able to fabricate that to my satisfaction. The curves are beyond my metal working skills. Bummer.
Thanks anyway guys - I very much appreciate the help.
JPSmit
curves are nice but not necessary - as long as there is something to stiffen the floor so it doesn't flex. Assuming you aren't doing a concours restoration, I'd still say go for it
T
tdskip
Hi John-Peter. I'm pretty comfortable that I could cut metal to fit and put a bend in it for stiffening, but I'll know it isn't right and it will bug me. Kind of silly given all the other imperfections - and there are a lot - on the car. I think I'm going to save for a replacement panel, use what I need, and then sell the rear section.
Thanks for the idea - for a less insane owner it's a good idea.
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
RCarr Windscreen Glass Options Austin Healey 2
Frameman 1949 Tire Options Austin Healey 16
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
boxofparts 100-4 Engine Options Austin Healey 12
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
R General TR Spring collar flange thickness options Triumph 2
P BJ8 Frame Rust Options? Austin Healey 14
Csarneson Fuel pump options Austin Healey 10
glemon General TR TR250 Steering Wheel Options Triumph 6
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
M Muffler Options with Exhaust Header Spridgets 1
B Leaf Spring Re-build Options? Other British Cars 2
Michael Oritt 100 Oil Pump--options and resources Austin Healey 12
Rut TR4/4A Restoration options Triumph 12
steveg Piston options for Healey Austin Healey 12
R TR2/3/3A front hub seal options Triumph 9
M TR2/3/3A Clutch options Triumph 9
N Wedge '80 TR7 Alternator Options Triumph 2
cmacmillan TR6 TR6 grille repair - thoughts? Options? Triumph 6
K TR4/4A Fuel tank options Triumph 4
maxwedge5281 gas filler and cap options Austin Healey 9
M TR4/4A Dash support covering.....options? Triumph 5
K TR2/3/3A Dash panel light bulb colour options? Triumph 5
D TR6 Rear Shock Refurb Options 76TR6 Triumph 15
C AH 100 Best Options for front and rear suspension? Austin Healey 9
RedTR3 TR2/3/3A TR3 Crankshaft Options Triumph 10
H TR6 TR6 camshaft options Triumph 9
RJS TR4/4A Brake Master Cylinder Cap Options Triumph 11
I TR2/3/3A TR3 tire options Triumph 9
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
CanberraBJ8 fuel tank options? Austin Healey 12
jhorton3 Brake Pressure Sensor Options Spridgets 3
Lbp TR2/3/3A Options for TR3 Wiring Harness? Triumph 7
B Spitfire 79 Spitfire Bumper options Triumph 2
DerekJ Lightened flywheel options Austin Healey 62
cologero_100 BN1 Heater Assembly Options? Austin Healey 2
T Cooling fan options Triumph 24
6 front hub options... Triumph 4
M Healey 100-4 Piston Options Austin Healey 1
Mychael Opinions wanted on carb options. Spridgets 15
W Options, Looking for opinions.... Triumph 2
W GT6 GT6 / TR6 Rotor Options Triumph 2
H TR2/3/3A TR3 heater options Triumph 9
T TR2/3/3A TR3B bolted wheel options Triumph 5
S TR6 71 tr6 exhaust manifold options Triumph 7
Boink Battery cut-off switch options... or??? Spridgets 10
R Overdrive/5 speed options for 1500 Midget? Spridgets 21
I Bugeye transmission options? Spridgets 11
B TR2/3/3A TR3 upholstery options? Triumph 14
