Though I have not yet dropped the sump to remove and examine the oil pump signs are that it is up for replacement: 55-60 psi at 2500+rpm's/30 psi at 1000 rpm's on start-up, falling off to 35-40 psi at 2500+rpm's/10 psi at 1000 when oil gets hot.
Assuming the pump needs to be replaced what is available out there? Unless I am missing something Moss does not seem to supply one for my car, though I do see one on the VB site. I don't mind springing for a more expensive product from UK if there is a real advantage in quality, performance and/or reliability.
Thanks in advance for all advice and opinions.
